IS300 - 4g63 swap build
Old Feb 23, 2013 | 09:35 AM
  #136
Installer88's Avatar
Update.
I have been working on the car, just have not been posting here. I have posted the updates on facebook, just too busy to make them into my build thread.
First, I made rear lower control arms. On vehicle adjustable. I like how they turned out. Now my rear suspension arms are mostly done.
Next I removed the rear subframe to make solid diff bushings.
I cut out all the old bushings to replace with solid ones. I wil post finished pictures later.
I mounted the seat, and mocked up the pedals. The pedals have a little bit of modifications before they are exactly how I want them. It is a wilwood reverse swing mount set. meaning the master cylinders are in the cabin. no abs, no brake booster. Just 3 master cyl's. 1 for clutch, 1 for front brakes, and 1 for rear brakes. Plans are for a driver adjustable bias crank.
I proceeded on with the racecar maddness by mounting the radiator. In the best location possible. In the trunk. Plans are for air underneath the car (channeled by the flat-bottom and ducting) to travel up and through the radiator. I did this for weight distribution, engine bay packaging, and a little downforce.
  #137
With all the fabrication just getting started, I decided to bust out the tubing bender.
You guessed it, roll cage time. I have been waiting for this time for a while. Actually have had the material for almost a year, just needed an uninterrupted weekend to devote to the car. I will let the pictures do the talking for now.
Here is my little secret for welding the top of the cage. This allows the cage to touch the roof of the car when installed, but still have 360 degree welds on the top bars.
The cage is about halfway done. Still a good deal left. If you are curious It is built to NASA and SCCA specs for road racing. Hope this update was big enough. But there is more, I just haven't taken pictures of it.
Old Feb 24, 2013 | 10:59 AM
  #138
Check out my thread here, and like it at the bottom of the page. If I get the most "likes" Before feb. 28th. i will win an aem failsafe gauge.
Lexus IS300 4G63, T56, 35R, Time Attack build | MotorMavens Readers Blog
Old Feb 24, 2013 | 09:29 PM
  #139
xXANCHORMONXx's Avatar
Cant wait till its done! Any more motor fitting yet?
Old Mar 4, 2013 | 06:39 PM
  #140
wizzo 8's Avatar
You got a like from me
Old Mar 10, 2013 | 08:17 PM
  #141
I haven't done any more engine bay work. The block is at the machine shop currently, but as soon as I get it back, I will be finishing the engine bay work. Honestly, I am trying to finish all the chassis prep stuff before I get the engine back.
And thank you guys for the likes at motormavens.
Old Mar 10, 2013 | 09:00 PM
  #142
VQChris's Avatar
cannot wait for the end result. This is nutty.
Old Oct 12, 2013 | 05:38 AM
  #143
Cutlassjim's Avatar
Wanting a 4 cylinder in an IS and not swapping in a 3S-GE and 6 speed trans from the Jap model is just asinine. The 3S can easily make just as much power as a 4G63 and it bolts right into the chassis. Plus they are only around $1600 from JDM importers.
Old Dec 23, 2013 | 10:49 AM
  #144
STOCK03EVO8's Avatar
Updates to this CRAZY BUILD??
Old Apr 10, 2014 | 08:53 AM
  #145
Atrophical's Avatar
pics don't work
Old May 13, 2014 | 12:08 PM
  #146
bill hincher's Avatar
This is the EVO 4 through 9 T 56 bellhousing in either short shaft or long shaft
Old May 15, 2014 | 09:38 AM
  #147
SmurfZilla's Avatar
1) He had the 4G lying around
2) He got alot of parts for the build for free
3) He does his own work and fabrication
4) because its his car and he can.
He mostly has sweat equity into it.
There are a lot easier ways to go faster but its different.
evo8jedi
Jul 25, 2022 07:58 PM
enjoiskater7788
Oct 17, 2015 05:31 PM
armstrong1
West Region
Sep 30, 2015 01:44 AM
DOOMID@TeamD
Feb 21, 2014 07:14 PM
evo8jedi
Oct 6, 2011 11:36 AM
