IS300 - 4g63 swap build
Old Dec 8, 2011 | 12:24 PM
  #91
teamspink20's Avatar
top mount
Old Dec 8, 2011 | 12:37 PM
  #92
High_PSI's Avatar
Wow what a crazy build!! If wewight is your issue why not a SR20-DET, they are Aluminum!
Old Dec 8, 2011 | 01:02 PM
  #93
Jrod@Buschur's Avatar
Originally Posted by high_psi
sr20-det, they are fail!
There we go... FIXED!
Old Dec 8, 2011 | 01:29 PM
  #94
High_PSI's Avatar
Oh What's wrong with the Nissan block?
Old Dec 8, 2011 | 01:50 PM
  #95
GdotRegEvo9's Avatar
crazy build gl
Old Dec 8, 2011 | 01:51 PM
  #96
Then I ask you.... Whats wrong with a 4G63?
SR20... the JDM version of the LS1...
Old Dec 8, 2011 | 03:58 PM
  #97
Installer88's Avatar
I am just not a big fan of the sr20. We have one in our shops s14, and it makes 460whp. I just am not a fan, also stroker kits are more expensive than for the 4g63. And the transmissions suck, even the z32 trans, we go through 3rd and 4th gear every other event.
I disagree about the sr being a jdm LS1. SR20 = JDM chevy 350, and 2JZ = JDM LS1
Old Dec 8, 2011 | 04:43 PM
  #98
wizzo 8's Avatar
I like the Supra style like above^^^
Old Dec 8, 2011 | 05:28 PM
  #99
Erockin's Avatar
Subscribed.
Old Dec 9, 2011 | 06:01 AM
  #100
After I wrote that lastnight and was driving home I thought to myself "Man, the 2JZ is the Japanese engine thats in almost everything custom built. Thats more of the JDM LS1.". Touche'
Old Dec 9, 2011 | 07:33 AM
  #101
I am one of the few that can say, I removed a 2jz, and installed an ls1, lol.
Today I started on the firewall. Making the new one is already taken longer than cutting the old one.
Old Dec 12, 2011 | 08:14 AM
  #102
Got more work done on the firewall.
I am going to have a removable section to access the rear CAS as well as the thermostat housing.
Old Dec 12, 2011 | 06:38 PM
  #103
wizzo 8's Avatar
Seems like the valve cover will be a little too close to the firewall. Maybe its just the pictures though.
Old Dec 13, 2011 | 05:14 PM
  #104
There is approx. 3.5" between the top of the valve cover and the bottom of the firewall extension
Old Dec 13, 2011 | 05:19 PM
  #105
wizzo 8's Avatar
Oh ok it was just the picture then. I was actually referring to the side by the intake manifold but from the top view it looks good.
