Test of Affect Air Temperature Has on Dyno Results
The blog below tests a Mazda 6 turbo on a dyno with same mods on the same day with different intake air temperatures. At 66 degrees it produced 262 WHP (smoothed value) with boost pressure dropping from 20 PSI to 18 PSI. At 88 degrees, it generated 230 WHP (smooth value) with boost pressure dropping from 20 PSI to 16 PSI.
http://stratifiedauto.com/blog/the-e...rged-vehicles/
20* should only be about 15-20hp. As razorlab said, the ECU is also doing other htings in the background reducing power. Likely less timing to go with lower boost with the higher IAT's.
and obviously boost. 4psi from a 20* charge temp change is a compensation for sure.
05blue8
Apr 11, 2009 06:51 PM
4g63girl
Mar 17, 2009 01:46 PM
dlowman
17
Sep 25, 2004 11:46 AM
