NA tuning questions
Old Jun 6, 2018 | 03:41 PM
CaliMR's Avatar
NA tuning questions
Hi, this is a non-Evo question as it is about NA tuning, but the other cars section appears to be dead and this is the only forum I still use. I have an NA motor in a bike that I'm adding an intake and full exhaust to, and the guy who makes the intake offers free maps to use. I'll probably get a custom tune, but it's kind of hard to find a place that will do it around here so I'll likely be on his for a while. He has a great rep, but most people do get custom tunes to go with his intakes.
Some of the places I ride only have 87 octane for 150 miles, and the tank only holds about 120 miles worth of gas, so I'll have to be splashing in a bit of 87 to make it to the next 91 station (CA, so that's the best you can get normally). He said to use his Eco (high mpg) tune when I can't get 91, because it is the safest tune. He also said I could use his non-ignition advanced tune if I wanted to, which he can send me but I could also just open the map and put 0 for all the advance fields. His advanced and non advanced tunes are exactly the same otherwise.
Note that any tuning eliminates the o2 sensor (it gets removed), and I don't think bikes have knock sensors.
I have some questions:
1. Isn't an Eco tune usually a lean tune? So wouldn't it normally be the most risky tune with low octane? Since it has no ignition timing changes, it should be leaner than the power non-advanced tune?
2. Is it odd that the advanced and non advanced tune are exactly the same aside from the advance? Trim, etc are exactly the same, one just has a couple degrees of timing added in.
I have only heard 100% good things about the guy and his products, other than "it could have been easier to install," and I know people with his full kit on their bikes (different models than mine but all have custom tune), so I want to trust him, but those two things seem odd to me. I also don't want to be an ***hole and call him out on his advice if I am completely wrong, hence why I'm ask y'all if it seems right first
Old Jun 8, 2018 | 07:22 PM
LetsGetThisDone's Avatar
Hard to say without know the motor and the guys tuning, but yeah, an eco tune, to me, would be lean..
And as far as an advanced vs non-advanced map and only timing being different, that's typical. Fuel demand doesn't change much with time unless it's a big change.
tscompusa2
35
Nov 18, 2009 08:20 PM
majestic lancer
Oct 13, 2003 07:02 PM
