Mid-Atlantic Region Includes DC, DE, MD, VA, WV.
HKS cams and AMS tune.
Old Dec 5, 2007 | 02:05 PM
  #61
EvoAngel429625's Avatar
haha
Old Dec 5, 2007 | 02:51 PM
  #62
Warrtalon's Avatar
Originally Posted by evo 8 ya
like rally cars that make 300whp and 450wtq that's really not a good thing huh I agree something is odd but with the readings but nothing bad.
We are not talking about rally cars - those are DESIGNED to be that way specifically to meet the rules. My comment was not a sweeping generalization for every car - the Evos in question here are NOT designed to do that, and it is not a good sign for a standard-modded Evo on pump gas and 22psi to be making 40-50 more peak WTQ than peak WHP - that is a bad sign and is not good for the car if it's truly happening.
Old Dec 5, 2007 | 06:10 PM
  #63
evo 8 ya's Avatar
I'm now truly convinced that you have no idea what you're talking about.
Making 40-50wtq more than whp is in no way a bad thing. Explain why it's bad.
Old Dec 5, 2007 | 06:24 PM
  #64
Silver06evo9mr's Avatar
ray your so f'in hilarious... SUBSCRIBED
Old Dec 5, 2007 | 06:36 PM
  #65
Exciting News's Avatar
You'll be accused of secretly desiring a 5.0 mustang which had many more torques than horsepowers. A bad thing indeed...
Old Dec 5, 2007 | 06:46 PM
  #66
Thrilla's Avatar
Veteran: Army
Interesting...subscribed.
Old Dec 5, 2007 | 11:30 PM
  #67
Warrtalon's Avatar
Yes, it is very much a bad sign on a stock turbo'd Evo running 22psi, because that is now how an Evo makes power at 22psi. The way we get big torque humps like that with the stock turbo is by running a ton of boost (race gas or alky/meth). Even then it's only a 20-30 point difference, and that's only due to the inefficiency of the stock turbo at high boost levels. It cannot sustain the boost levels required to hit such a high torque level and thus peters out as RPMs increase thus resulting in lower peak WHP numbers due to the obvious hp/tq calculation.
When Evos are setup like this, sometimes they have problems that result in steep WHP dropoffs on the top-end. Sometimes, it's knock caused by the extreme boost being run on the low-end that causes timing pulls that carry through to the top-end. Sometimes, it's a boost leak that manifests itself as RPMs increase due to the hairdryer effect, and sometimes it's knock from the extreme stress put on the motor when pushing so much torque so quickly so low in the RPM band.
I don't know why you're fighting this the way you are and attempting to belittle me here when this stuff is quite obvious and well known. You show me some examples of stock turbo'd Evos running numbers like this on 22psi and/or Evos running numbers like this on mega boost and high octane where it's normal and without problems.
Anyway, so far you've ignored what I'm really saying and are attacking things you THINK I'm saying. It's not a bad thing to have torque. It's just a bad SIGN for a stock turbo'd Evo running 22psi on pump gas to have such a large discrepancy in WTQ/WHP, because it indicates problems with the car (or with the dyno).
Old Dec 6, 2007 | 05:52 AM
  #68
05blackevo8's Avatar
I have to say, for once, im not disargreing with Warrtalon. My car at 22psi made 320whp and 295wtq on the mustang dyno. Running alky and 28ish psi my car made 333whp and 342wtq. The boost would spike high to make all the tq and than by redline im back down to like 21ish Psi. I also have the Forced Performance WGA and the stock turbo still cant sustain boost that high to make the HP at the higher revs
Old Dec 6, 2007 | 06:29 AM
  #69
evo 8 ya's Avatar
So what are your implying? SE's should be making more power than 350whp @22psi with BPU + cams? Or that all SE's come with boost leaks? The car was obviously logged with no knock or an exceptable amount of knock because mike knows what he's doin when it comes to tunning. It could be due to colder weather, only a back to back compairison will tell. But in no way is it bad.
Do you even know how you would make more wtq than whp in a turbo car?
If you want an example, my completely bone stock 03 made 218whp and 244wtq. I have a dyno sheet. My friend's IX made 386whp and 411wtq. Some cars make higher torque, plain and simple. It's usally V8s that do it, but none the less. Check power and torque figures on a turbo diesel. They make 2-3 times the amount of torque than actual power. It's not a "bad sign" or necisaraly anything wrong with the car. I don't know about you, but I love torque and would be happy as **** to be making that much more torque without perposley trying to.
I'm not trying to belittle you, but when you just say it's a "bad sign" with no kinda backing or proof, spouting off a bunch of bs that's just speculation, you bring it upon yourself.
Old Dec 6, 2007 | 06:45 AM
  #70
SPEED's Avatar
wow...that's a lot of torque at only 22psi. Interesting...
Old Dec 6, 2007 | 09:01 AM
  #71
this thead is getting out of control i love it... who woulda thought brian?
Old Dec 6, 2007 | 09:02 AM
  #72
+1 ^^
Old Dec 6, 2007 | 09:05 AM
  #73
i agree, it isnt a bad thing, i just dont think it is normal for an evo to be making that tq at so low boost. Lets just get multiple cars and test this already
Old Dec 6, 2007 | 11:14 AM
  #74
eVo Stance's Avatar
Bone stock IX SE for sale in NJ :
http://newjersey.craigslist.org/car/496945827.html
Old Dec 6, 2007 | 03:27 PM
  #75
chrisevo8's Avatar
Those are good numbers....im interested in seeing your car again
