Midwest Region Includes IA, IL, IN, MI, MN, MO, WI, OH.
Clutch installation in chicagoland
Old Mar 25, 2008 | 07:15 PM
J8dailo's Avatar
i just got my car back...the exedy stage 2 grabs like a mother...still getting used to it and need to break in... is it normal for this clutch to have 1 - 1/2 inches of freeplay??
Old Mar 25, 2008 | 07:56 PM
EricJ@AMS's Avatar
Freeplay at the top of the peda? Definatly not, it should have the same amount of freeplay as it had stock.
Old Mar 25, 2008 | 08:02 PM
J8dailo's Avatar
ya..there is alot of freeplay on top of the pedal...about a good inch to an 1 1/2.. it doesn't feel anything like stock.... adam wasn't in when i got there cause i got there really late so i just paid and picked up my car....
Old Mar 25, 2008 | 08:26 PM
beemerfreak's Avatar
U might need to adjust ur clutch pedal.
The Exedy stage 2 is the 4 puck right?
U should of gone with the ACT Street HDSS. Much better daily driving, and holds more power.
Old Mar 25, 2008 | 08:41 PM
J8dailo's Avatar
heard so many people have issues with act... maybe its just me... it just feels like its really easy to push down for about 1 1/2 inch then i feel tension...clutch engages near the bottom of the pedal...im not sure if thats how its suppose to be or what... but it feels nothing like stock...
Old Mar 25, 2008 | 09:18 PM
sblvro's Avatar
I adjusted my stock clutch to feel just like that, engages near the bottom of the pedal. If you want it higher you can adjust it following the "evomoto" technique.
Old Mar 26, 2008 | 05:51 AM
MasterNater's Avatar
Clutch Pedal Adjustment:
https://www.evolutionm.net/forums/sh...d.php?t=260040
Old Mar 26, 2008 | 07:52 PM
J8dailo's Avatar
this is my first time getting a new clutch and still getting used to the new feeling... im not sure if this is normal or not but it doesn't feel right to me... in forward...the clutch vibrates the car at take off even when i give it gas...i hear a noise coming from trans....in reverse...it grabs right away and engages really smoothly with no vibration what so ever...maybe its just the break in process...i been keeping the rpm below 3500 the whole time until i hit 500miles..
Old Mar 26, 2008 | 08:06 PM
J8dailo's Avatar
nevermind...i read bunch of thread and alot of people have this issue...i guess its just normal break in period and characteristic of exedy stage II... also im curious... im thinkin about taking out the restrictor at the release cylinder...would that make the engagement too harsh for DD or would it improve engagement with no driveabilty problem?
Old Mar 26, 2008 | 09:44 PM
EricJ@AMS's Avatar
A customer brought a car in with an ACT with the clutch adjusted low like that complaining of lockout/grinding issues when shifting hard. I test drove it and sure enough, it was real bad. I adjusted the clutch back up to oem specs, and presto it shifted like it had a brand new shep race trans.
Keep your pedals high like they come stock guys. The pull designs are like that for a reason!
Old Mar 31, 2008 | 05:08 PM
Creamo3's Avatar
How are you liking the Exedy Stage 2; I think my clutch is starting to die on me and will probably be getting a new one soon. I was also considering the ACT Extreme as I currently have the ACT Heavy Duty and liked that. I may have to give DEVO a call to see what they charge.
Old Mar 31, 2008 | 10:27 PM
J8dailo's Avatar
devo charge the cheapest as far as clutch install is concerned... the stage 2 is starting to feel more like stock more...thats a plus in my book
Old Apr 7, 2008 | 03:22 PM
J8dailo's Avatar
Update: the clutch has 800 miles on it and well broken in and feeling alot like stock just a bit heavier.... somethings i notice is that its really hard to get into reverse from neutral and some of the foward gears also....i read somewhere that i might need a extended slave cylinder rod for aftermarket clutch to resolve this problem?? and also...another thing is it get noisy sometimes and for some reason....every time the clutch is pushed in....with car on or off....the clutch squeeks like crazy....im not sure why or if its going to go away sooner...lack of lubricant? i am not sure...any help would be good...thanks
Old Apr 7, 2008 | 10:14 PM
sblvro's Avatar
wow, did they not replace the release bearing? that is usually what happens when it is worn out
Old Apr 8, 2008 | 05:54 PM
J8dailo's Avatar
i am not sure on that one...i just dropped it off and told him my situation about getting a new clutch installed and flywheel resurfaced...
