Midwest Region Includes IA, IL, IN, MI, MN, MO, WI, OH.
Evo 8 mivec swap
Old Apr 30, 2011 | 11:01 AM
governmule's Avatar
Evo 8 mivec swap
I am getting a mivec with 30000 miles on it and swapping it to my 03 VIII. Anyone know what complications I might run into?
Old May 2, 2011 | 09:37 AM
APM Racing's Avatar
Beyond the oil lines, make sure the Evo 9 ecu and engine harness are there as well as a set of cams.
-Mark
Old May 2, 2011 | 06:48 PM
governmule's Avatar
I have all the wiring and ecu and I'm getting the entire engine and turbo so i think it should just all bolt up. This is my first evo engine swap. I'm worried about putting all the wiring back right.
Old May 3, 2011 | 09:52 AM
APM Racing's Avatar
As long as you have everything and it was never cut or modified, you'll be fine...it'll only fit one way.
-Mark
Old May 3, 2011 | 09:54 AM
APM Racing's Avatar
If you need some help, let us know, no biggie, that's what we're here for.
-Mark
Old May 10, 2011 | 08:39 AM
APM Racing's Avatar
How'd this go for you btw?
Old May 11, 2011 | 12:17 PM
governmule's Avatar
Well so far not as good as I'd hoped. Just a bunch of problems. The current problem is that no matter what I do with my boost controller I can't boost more than 10psi.
Old May 11, 2011 | 12:22 PM
APM Racing's Avatar
It's either the way it's hooked up or the wastegate of the turbo. The rod could be bent or the diaphragm torn, whatever it may be it's more along those lines. Who's MBC is it?
-Mark
Old May 11, 2011 | 01:16 PM
APM Racing's Avatar
It may be the MBC, that's why I ask...I might have to see the car if the boost comes on like normal but only hits ten psi. If it comes on later, then it may be the wastegate then.
-Mark
Old May 11, 2011 | 03:31 PM
governmule's Avatar
It was fine when I went straight without the mbc, boomba btw, and it boosted to 22. I put the controller back in and it takes a long time to boost and only hits 10. I tried putting the mbc both ways to make sure I had it right.
Old May 12, 2011 | 12:38 PM
APM Racing's Avatar
It's the controller, like I said above, there's only a few options for things to go wrong, go and return it if it doesn't work.
Get yourself a Hallman or AMS or we make our own as well...we run it on a few different power rated cars and they work. Keep it single, don't so all these different stages or whatever.
-Mark
Old May 12, 2011 | 02:35 PM
APM Racing's Avatar
Or get it warrantied
-Mark
Grimgrak
Apr 28, 2015 01:49 PM
shadow_X
May 4, 2013 09:49 PM
booster9
40
Mar 18, 2009 02:32 PM
TakaseEVOIXSE
Mar 17, 2009 11:19 AM
1320awd
14
Nov 10, 2008 01:27 PM
