Temp Switch for SSP SST Cooler
Old Jun 27, 2017, 06:30 AM
Roen's Avatar
Could I adapt this switch to make the SSP Cooler temperature-sensitive instead of switched?
SW536
(View Image) 2 Male Blade Terminal M16 x 1.5 Open Makes 190f ± 6 Breaks 174f ± 6
http://www.yoyopart.com/oem/11344555...ml#interchange
http://www.ebay.com/itm/Engine-Cooli...QAAOSwvjdZRXpu
Are the make and break temperatures appropriate?
Old Jun 27, 2017, 11:15 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
I would have the fan come on at 210, turn off at 190-195. Have the fan controlled by the relay. Let the relay draw from a high amp source, like the battery post in the engine bay. For the control side of the relay, give it power from a source that is on/off with the key, then have the switch control the ground for the relay. That way the switch never sees much load. So, you'll want an NO switch that closes when the temp gets up.
Old Jul 7, 2017, 07:12 AM
Roen's Avatar
Why turn on the fan at such a high temp? I thought operating temp was 180?
Old Jul 26, 2017, 07:38 PM
Jaraxle's Avatar
Here is what I used successfully:
https://derale.com/products/fluid-co...ack-hub-detail
It can control up to a whopping 15amp fan. I literally just cut the hose going to the OEM SST cooler and clamped this guy in place with two worm-gear clamps (-8an matches the 1/2" hose). The SPAL fan that I mounted on the cooler pulls something like 5 amps. All you then need is a fuse piggyback that adds a fuse (any auto store), and make sure you use a slot that is switched by ignition. As for temperatures, the OEM thermostat sends SST fluid for cooling at 150F. It is therefore believed the correct temperature for the fluid is between 150F and 200F. Things go horribly south at 274F. So having the fan turn on at 180F and off at 165F is perfect. I have been quite pleased with this setup for over a year.
Adding (improved) ducting TO and FROM the cooler/fan would help even more, and is on my todo list.
~Jaraxle
Old Nov 4, 2017, 11:43 AM
MNC5's Avatar
Just ordered it up for SST cooling upgrades.. Thanks @Jaraxle
Anexos
Apr 1, 2015 02:53 PM
Roen
Mitsubishi TC-SST Discussion
Jul 21, 2014 02:53 PM
Roen
Mar 19, 2014 08:29 PM
5harkology
15
Nov 1, 2011 06:01 PM
Quick Reply: Temp Switch for SSP SST Cooler
