MR launch control
Old Jul 13, 2010 | 09:24 AM
  #31
migs647's Avatar
Originally Posted by kmart888
I don't have the chart availiable for the gasoline pull but I got 330 awhp on a Dynopack with just a full tbe (no cat), stock intake with drop in filter, CA 91 oct fuel, and an ots Cobb AP stage 2 tune; same setup did 340 with a custom tune and 375 on e85 with 1000cc injectors a Blaqops pump and a custom tune.
Isn't the dynopack measured at the hubs vs wheels? Just saying.
Old Jul 14, 2010 | 09:06 AM
  #32
kmart888's Avatar
Quite true but with the correction factors plugged in I'm told (by the owner of the dyno) that the numbers were equivalent with local wheel driven dyno's. I had the e85 setup on a local DYNOmite wheel driven dyno and the Dynopack was was 5awhp and 10lbft optimistic (370.4awhp/392.3lbft) compared to the DYNOmite (364.6awhp/384.8lbft) respectively.
Perhaps a better comparison of real wold power is 1/4mi terminal speed, 108mph on 91, 112mph on e85
Old Jul 14, 2010 | 09:49 AM
  #33
migs647's Avatar
Yah I usually don't trust corrected factors :-/. Dyno owners will usually do anything to justify their dyno vs others. One of the reasons I like the dynojet, there is no correction factor. Mustang (uncorrected) and dynojet #'s are the ones I usually trust. Either way, it goes without saying that a dyno number means nothing, it's only a tool to measure gains and to tune on. It isn't a **** measuring contest. But 340 seems extremely high for those mods when most bases are around 240wheel. Either the dyno is either off by quite a bit compared to other base numbers or the tune is ultra aggressive, in which I doubt it will last very long.
But this brings up an interesting point with the 1/4 mile. How does one measure 1/4 and 0-60 on an MR... do you launch it? Do you do it from a roll? Do you do it from a complete stop?
Old Jul 14, 2010 | 10:46 PM
  #34
usarmy1113's Avatar
0-60 times can be measured by the cobb accessport and so can the quarter mile and 60 foot. I imagine the 0-60 6imes and 60 foot measures are pretty accurate, I dont know about the quarter mile though
Old Jul 14, 2010 | 10:55 PM
  #35
migs647's Avatar
Well my real question is how do you do a 0-60 in the mr. Launch, or roll, or from stop then gas it.
Can always measure with a video cam
Old Jul 14, 2010 | 11:02 PM
  #36
usarmy1113's Avatar
launch it, thats what will make you get the fastest times! i clocked 4.25 in the 0-60. s-sport mode, hold traction control till completely off (2 seconds), stomp on brake, floor gas at the same time, revs will hold at 5500 and let go of brake and enjoy
Old Jul 14, 2010 | 11:11 PM
  #37
migs647's Avatar
Please tell me 4.25 was stock or on a minor tune...
Old Jul 14, 2010 | 11:32 PM
  #38
usarmy1113's Avatar
cobb stage 2, turboback exhaust and drop in filter, thats it
Old Jul 15, 2010 | 08:33 AM
  #39
kmart888's Avatar
1/4 and 60ft times are measured at the drag strip using launch control from a standing start, just punching it from a standing start (without launch control) usually yields about a 2.2 - 2.4 60ft, still faster than it "feels". I have never measured 0-60mph, although I have an AP I don't trust it for an accurate measure of acceleration so have never bothered.
Dynojet certainly uses correction factors, I have used the Dynojet over the years on my 2 wheel drive cars and the SAE correction numbers differ each time the manufacture updates their software.
My basis, if I remember correctly, on the DYNOmite is stock 255 hp, and close to 295 hp with a pro tune, 330 hp with TBE+testpipe so about +35hp and 6mph (108-102) in 1/4mi trap speed due to TBE and test pipe alone. My car runs strong but it is no freak, my results can be safely replicated by most anybody with a healthy evoX.
FWIW, I have abused my car by running it WFO right to the redline (and sometimes the rev limiter) from the get go with only 20mi on the clock, been running the present tune since 2000 mi. I now have over 25,000 Daily miles on the clock with multiple drag strip launches thrown in and the car looks runs like new.
europaul
Mar 16, 2016 10:12 AM
Doberzus
Nov 6, 2013 09:40 AM
extremier
Mitsubishi TC-SST Discussion
Aug 25, 2010 05:36 PM
R/TErnie
May 18, 2009 10:44 PM
blockbuster
Jul 1, 2008 11:57 AM
