Tranmssion sound at startup while brake engaged
Old Aug 5, 2012 | 10:49 AM
dj3po's Avatar
When I start my car with either the foot brake or the emergency brake engaged, a loud clunk/grind happens. When I start the car without either engaged, the sound does not happen. Is this normal with SST transmissions? The dealership said I would have to drop the car off for a day or two in order to investigate. If it's a normal sound then I won't bother.
Old Aug 5, 2012 | 04:48 PM
richardjh's Avatar
I grind isn't really normal. You should bother.
Rich
Old Aug 6, 2012 | 04:13 AM
dj3po's Avatar
Rich
Thanks...taking it in this week. Warranty is almost up!
Old Aug 6, 2012 | 06:13 AM
richardjh's Avatar
Be very demanding as a customer.
If they fob you off with a "wait and see" approach, get written confirmation from Mitsubishi rep that IF the grind is in fact heralding an SST failure, then they will treat it as a warranty repair... because the problem was formally noted while still under warranty.
etc. etc. Sorry if I'm giving a course in sucking eggs.
Rich
Old Aug 6, 2012 | 07:05 AM
gaabbee's Avatar
Im pretty sure i figured out what the grind on start up is all about. The starter is getting hung up on the flywheel. Its probably a lubing problem but unless someone wants to try replacing the starter im not gonna worry about it.
Old Aug 9, 2012 | 01:37 PM
resident's Avatar
Hi, it is seems that I got the same problem as you had.
Could you please check my topic
https://www.evolutionm.net/forums/mi...l#post10331357
is the problem the same as yours? how do you fix it?
Old Aug 10, 2012 | 03:47 AM
dj3po's Avatar
So I just got my car back from the dealer. They performed an air bleed procedure on the transfer case. So far so good. I also found out there was a recall with the headlights that was just issued. It was listed as "reaim headlights recall."
Old Aug 14, 2012 | 06:11 PM
BeyondLimitsEvo's Avatar
It's a SST issue. I had it in my MR almost every time I started it. It would lurch forward slightly also.
05OBP
Dec 22, 2016 12:29 PM
RoBear
19
Aug 10, 2016 07:12 AM
The_Police
Apr 6, 2016 07:05 PM
samshowerman
Mar 28, 2011 04:34 AM
j14mp
15
Jul 10, 2009 11:36 PM
