sst problem urgent help needed
Old Nov 9, 2013 | 02:17 PM
marlonmck's Avatar
When I'm driving in manual mode on my fq 300 sst and moving off in first gear I can see rev count moving up and it also happens when I'm driving in third gear it keeps rev up and down and you can feel the reving in an unstable way. I'm clueless as to what is happening help me please.
Old Nov 9, 2013 | 02:39 PM
Iowa999's Avatar
If it does it in 5th, as well, then your 1-3-5 clutch is slipping, maybe due to low pressure (e.g., that line needs to be bled) or something with the plates, themselves. 5th should be the worst of the three, in fact, if my theory holds up.
Old Nov 9, 2013 | 07:13 PM
marlonmck's Avatar
I haven't noticed it in 5th. It's just slightly in 1st and a lot in third. Before I bought the car I was told that the transmission was being serviced. So I was hoping I wouldn't encounter any problems. But this has me stressed out as to what is happening.
Old Nov 9, 2013 | 09:07 PM
Iowa999's Avatar
Floor it in 5th. Those are the data we need.
Old Nov 10, 2013 | 05:46 AM
marlonmck's Avatar
Ok I will do that and see what happens and let you know. I'm wondering if i change the tranny fluid it will change for the better
Old Nov 10, 2013 | 06:56 AM
Iowa999's Avatar
Transmission fluid would affect the even-numbered gears, as well.
Old Nov 10, 2013 | 07:19 AM
marlonmck's Avatar
So do you suggest changing the fluid and all should be well
xi
Mitsubishi TC-SST Discussion
15
Jan 10, 2017 07:37 PM
hotsos
Mar 11, 2015 02:56 PM
Wille
May 16, 2014 09:13 AM
sirchumpalot
27
Nov 28, 2012 12:07 PM
triso
Jun 9, 2009 01:43 PM
