Won't shift 3rd,5th | P2440 Code?
Old Oct 31, 2014 | 10:26 AM
8OhOh2's Avatar
I have not had any SST issues with the car. Today on the way to lunch the car would not shift into 3rd/5th only R/1/4/6. I scanned the SST and it showed P2440. I can not find any reference to this code. After this everything is fine.
Thoughts?
Old Nov 2, 2014 | 07:01 AM
8OhOh2's Avatar
bump
Old Nov 2, 2014 | 08:51 AM
todd6027's Avatar
trans codes go from p0600--->p0899 what did you scan it with ???
Old Nov 2, 2014 | 10:35 AM
8OhOh2's Avatar
evoscan 2.9
I am new to this but it looks like there are higher digit SST codes:
P2718: Clutch/shift pressure solenoid 1 system (Open circuit)
P2719: Clutch/shift pressure solenoid 1 system (Overcurrent)
P2720: Clutch/shift pressure solenoid 1 system (Short to ground)
P2721: Clutch/shift pressure solenoid 1 system (Short to power supply)
P2727: Clutch/shift pressure solenoid 2 system (Open circuit)
P2728: Clutch/shift pressure solenoid 2 system (Overcurrent)
P2729: Clutch/shift pressure solenoid 2 system (Short to ground)
P2730: Clutch/shift pressure solenoid 2 system (Short to power supply)
P2733: Clutch/shift switching solenoid 1, spool stuck
P2736: Clutch/shift switching solenoid 1 system (Open circuit)
P2738: Clutch/shift switching solenoid 1 system (Short to ground)
P2739: Clutch/shift switching solenoid 1 system (Short to power supply)
P2741: Fluid temperature sensor system (Gradient error)
P2742: Fluid temperature sensor system (Output low range out)
P2743: Fluid temperature sensor system (Output high range out)
P2766: Input shaft 2 (even number gear axle) speed sensor system (Poor performance)
P2809: Clutch/shift switching solenoid 2, spool stuck
P2812: Clutch/shift switching solenoid 2 system (Open circuit)
P2814: Clutch/shift switching solenoid 2 system (Short to ground)
P2815: Clutch/shift switching solenoid 2 system (Short to power supply)
Old Nov 2, 2014 | 11:50 AM
todd6027's Avatar
il see if i can get hold of a wsm in a few mins
Old Nov 4, 2014 | 02:59 PM
8OhOh2's Avatar
Let me know if you can get a hold of it
bossdavis88
Lancer Tranny/Drivetrain Tech
Mar 9, 2025 10:05 PM
meeklo062704
13
Sep 21, 2015 07:57 PM
alpinaturbo
28
Sep 10, 2013 08:22 AM
dtuned
Jun 4, 2009 02:02 PM
chase123
Feb 9, 2009 09:00 AM
