Sst cooler fluid flow direction !?
Does the hot transmission fluid enter the cooler at the top like a typical car radiator would or does the hot enter the bottom of the cooler (like some Hondas) ? I inspected the Mitsubishi tc-sst repair manual and it does not indicate flow direction.
You are correct. Mike from road race engineering was kind enough to answer this for me. Pulling a hose off would have been a messy situation. The bypass also would have made this a hit or miss, but I greatly appreciate your response..
This is expected due to the bypass I understand. I am more interested in overheating on the track. If the temp isn't reading 150F then I also know the clutch packs are not up to temp. I had no idea if was actually labelled. Knowing the hot fluid goes into the bottom of the cooler was the key thing since that is the boss I trigger the fan off of and now also read the temp. Thanks!
a2b
Nov 12, 2012 10:24 AM
migs647
Mitsubishi TC-SST Discussion
Sep 19, 2010 01:48 AM
Speed Element
EvoX 'For Sale' Engine Internals and Drivetrain
Jun 14, 2010 04:30 PM
LVSBB6
10
Aug 29, 2009 12:25 PM
Kmac
Jul 13, 2008 09:46 PM
