DCTF options
Old Dec 28, 2020 | 11:07 AM
devoyl's Avatar
5 Year Member
DCTF options
So im purchasing my 1st set of DCTF oil for my 14 MR and my search on the forum as discovered no one is ever sure of which DCTF to use
DiaQueen which is like $200 for 4 litres
Redline, AMSoil, or Motul all of which is significantly cheaper in comparison. about 8 litres for $160
Since i live in the US and the castrol transmax isnt available, im left with picking from the later.
Most posts i see, people are scared (as they should be) to use anything except diaqueen. I would have to pay to ship it as the dealer is charging close to $250 a container.
as for the the other 3, I noticed Jack Transmissions seemed to go exclusively with Motul which is great because i hear Jack is amazing with SST transmissions.
So at this point I'm stuck thinking that its too good to be true or im so behind in advancement, that Motul is the right way to go based on Jack Transmissions imo.
Old Dec 28, 2020 | 11:45 AM
LetsGetThisDone's Avatar
Literally every single thread says the same thing. Use ONLY the OEM fluid. You can order it with the filter from Kozmic. No one is "scared" to use other fluid. Other fluids seem to almost Always cause problems and you spend way more then $40 you saved by using the wrong fluid.
Kozmic has the filter for $35, and they don't have the fluid on their site anymore but I'm sure you can call to order it, or you can get ti from ExtremePSI for $196 for a 4L jug.
https://www.kozmicmotorsports.com/pr...xternal-filter
https://www.extremepsi.com/store/Mit...-4-litres.html
Old Dec 28, 2020 | 01:38 PM
jrsimon27's Avatar
Iam using motul dctf and after doing a lot of reading iam changing it out to diaqueen oem i have used it for 1500miles hope nothing damages car feels exactly the same as with the oem fluid it had.
Old Dec 31, 2020 | 06:38 PM
deylag's Avatar
I believe Castrol Transmax DCT fluid is repackaged as OEM Diaqueen. After seeing and smelling Diaqueen SST fluid and Castrol Transmax I can attest that they are similar.
I put Castrol Transmax into a Built Kozmic SST and if IIRC the transmission saw more than 20 pulls with no issues.
Opieoils is where I believe you can purchase it. UK distributor and they will ship to the US.
Its also recommended to do a teach-in for the SST after every fluid change.
Old Dec 31, 2020 | 06:51 PM
devoyl's Avatar
5 Year Member
Wow thank you! I'll have to definitely check them out. Unfortunately I just made a purchase of diaqueenz so next time for sure.
Old Jan 20, 2021 | 01:52 PM
devoyl's Avatar
5 Year Member
So im prepping for the SST fluid change and also rear diff & AYC fluid changes.
I was only able to purchase GL-5 gear oil for the differential and of course some diaqueen fluid for the Transmission.
Will any SP III fluid work to replace the AYC fluids since i cant find any Mitsubishi ATF SP III local?
I'm trying to complete all the changes tomorrow.
Kenpachi Zaraki
May 15, 2023 07:25 PM
parralegend
Australian Forum
Nov 17, 2012 06:01 PM
Ralliart367
Nov 12, 2012 01:53 AM
Methodical4u
Jul 25, 2009 09:34 PM
EvoJoeIX
Jan 27, 2008 01:49 PM
