Help reading EGT guage!!
Old Jan 6, 2005 | 09:16 PM
racerferrari's Avatar
i just installed my EGT guage....anybody can help me with reading it?...what should it be at normally?...any help would be great....thanks...wayne...www.pulpracing.com
Old Jan 7, 2005 | 11:10 AM
Stop&TurnFreak's Avatar
I am not sure, but I have a friend who can help. He has a wide-band and an EGT. I don't know why folks go with the EGT, no offense, because good widebands are so cheap now. I will get an email off, and let you know.
STF
Old Jan 7, 2005 | 04:41 PM
Scottybob's Avatar
The problem with trying to compare numbers on an EGT is that the temps will vary depening on where the thermocuple is located, brand, quality.
What I have always done is take readings on the EGT with the car stock and then use that reference to make sure I'm not getting too hot as the power comes up.
Old Jan 7, 2005 | 08:34 PM
mine starts out about 800 then goes up to around 1000 and then goes up to about 1350 as i get on it....i wonder if thats too hot?
Old Jan 7, 2005 | 11:16 PM
tcc's Avatar
tcc
What type of readings are you getting from what speeds, accelerations, rpm, etc?
racer - F or C?
Old Jan 8, 2005 | 10:29 AM
chrisw's Avatar
it depends on where you installed the probe. If your off runner #1 on the exhaust manifold, it sounds about right.
If your probe is after the turbo, it sounds a little hot.
Old Jan 8, 2005 | 11:17 AM
its located in #2 (passenger side)..bout 2.5 to 3 inchs from the block...its in F not C....the probe may not be 1/3 in like the instructions say...don't know if that effects the readings at all....i'm not sure what speeds but i'm not redlining it...thanks guys for your help
kimletrim
May 5, 2008 10:42 PM
EVO8HKS
15
Jul 15, 2007 04:57 AM
smokedmustang
211
Mar 16, 2006 04:51 AM
ev08buoy
15
Nov 18, 2005 09:52 PM
jbigelow
14
May 3, 2005 08:46 AM
