Comprehensive Evo STU prep thread?
Old May 3, 2007 | 04:52 AM
  #421
Czubaka's Avatar
The relative ride heights are probably more important due to the effect of the roll-centers for each end of the car. The Subarus employed the same effect of a lower rear roll-center to aid turn in...and that's all I know...
Old May 3, 2007 | 07:08 AM
  #422
russjnco's Avatar
Last year I went a half inch lower in the front over the stock rake difference and my consensus was that the car didn't like it at all. The weight seemed to instantly want to transfer up front and would cause the car to plow. This year I went back to the stock rake differential and the car is better as it wants to transfer weight to the back, especially during corner exit.
Old May 4, 2007 | 07:15 AM
  #423
donour's Avatar
Bridgestone RE-01R users:
Without giving away the farm, what pressures have you found worked the best? Have you found you have to run lower during the first run to generate heat?
Please post the tire size, rim size, surface, and weather conditions.
For example: on asphalt with the 615s, I found that I had to run around ~40 psi for 245/45/17 on a 8.5" rim to get the required sidewall stiffness and stave off roll. When I moved to a 9" rim, I could run 3-4 psi less with the same tire. Same stiffness, datalogger showed grip went up.
thanks
d
Old May 4, 2007 | 07:33 AM
  #424
evo8dad's Avatar
I just ran an event last weekend with air temps in the 70s, I forget track temp. Using my pyrometer I started low, 36/38 but, ended up running 41/43. I think the fronts actually could use a little more psi, say 41.5 or 42.
Tires are obviously 245/45/17s on 9.5 rims.
Old May 4, 2007 | 07:38 AM
  #425
donour's Avatar
Thanks. Were you running the higher rear pressure to get rotation? This is something I often did with the stock suspension, but with coilovers, I haven't found it necessary.
d
Old May 8, 2007 | 08:55 AM
  #426
cityhugo's Avatar
Is there any legal STU aftermarket clutch out there thats stronger then the OEM one?
My clutch took a dump on me this weekend and I really dont feel like putting another OEM one in there.
Old May 8, 2007 | 09:01 AM
  #427
evo8dad's Avatar
d
Yeah, I use the higher pressures in the for that extra bit of rotation and I'm running Robispec'd KW Variant 3s, which I am still trying to setup.
Old May 8, 2007 | 09:37 AM
  #428
CDeutsch's Avatar
Do you know what your spring rates are? I had Robi Spec V3's last year that were originally purchased more for the street then AutoX and at the national level the spring rates just didn't cut it. With the Zzyzx coilovers my spring rates are much higher and the results in my local PAX scores have been dramatic so far. The best thing was on my commute to work today I had completely forgotten I was in a prepped car. The ride was more comfortable then the tired stock shocks and springs on my Stealth TT (normal daily driver)!!! These things are awesome!
Old May 8, 2007 | 09:42 AM
  #429
evo8dad's Avatar
Don't even tell me that I was torn between the KWs and the Zzyzxs last year but, the Zzyzxs weren't available yet. I am running 9kg up front and 8kg in the rear. What rates on your Zzyzxs?
Old May 8, 2007 | 10:04 AM
  #430
CDeutsch's Avatar
That's good. I was only at 6kg in front and 7kg in the rear last year. I'll have to ask Steve at Zzyzx how much info I'm allowed to share on the setup (since my setup is entirely his doing at this point) and then get back to you. Or if he reads this I'll let him chime in.
Old May 8, 2007 | 10:17 AM
  #431
evo8dad's Avatar
Secret, secret That's cool I understand. Hopefully he'll chime in or at least PM me.
Old May 8, 2007 | 12:11 PM
  #432
DaWorstPlaya's Avatar
Unfortunately NO ... this is one of my issues with this class, its supposed to allow all common street mods but doesn't allow clutch upgrades. I'm sure its to avoid having people upgrade to 4 puck or 6 puck racing clutches or even twin disk clutches but some simple wording in the rules could amend that ... oh well.
Old May 8, 2007 | 12:54 PM
  #433
kekek's Avatar
Hugo,
How come your clutch is busted but Kevin has no problems and launches his stocker with 285's like it's going out of style?
Old May 8, 2007 | 01:14 PM
  #434
CBRD's Avatar
remove the restrictor pills....
cb
Old May 8, 2007 | 01:34 PM
  #435
CDeutsch's Avatar
cb
That's not legal either.
