Autocross EVO - Street Modified Build
Old May 5, 2007 | 07:13 AM
  #346
nick735's Avatar
Originally Posted by markdaddio
Any new england guys planning on getting out to the CART event at Laz parking in Hartford, CT? I will be making the trip, supposed to be a large smooth lot.
I was under the impression that it was on the smaller side... If its a decent size I'll probably go. I guess I'll have to google map it. Does anyone know the exact address?
Old May 5, 2007 | 11:46 AM
  #347
kekek's Avatar
A google maps search shows a pretty sorry looking lot. Guess it can't be worse than the old Bristol lot.
There's a fair amount of people running Warminster, PA tomorrow so you'd have some benchmarks there. Just a wee far at 160 miles from my house.
Old May 5, 2007 | 12:15 PM
  #348
boostinpsi's Avatar
how long can you expect a set of 285/40/18 v710s to last as long as your not over driving them? same with the hoosier A6/R6 would the R6 be a better choice for longer tread life because its harder to get them to temp or no?
im starting to do some research for next years setup. i wont be able to run a ful prepped bsp car but i want the suspension/tires to be up to par. bsp suspension with stoc power ftw!
Old May 5, 2007 | 07:00 PM
  #349
Warrtalon's Avatar
It's 285/30, fyi. You can go 120 runs or so. They typically run out of heat cycles before cording.
R6 is for road racing - not good for autocrossing due to the heat factor. A6s will last about half as long as V710s but maybe be a little faster.
Old May 6, 2007 | 01:04 PM
  #350
Loser's Avatar
Hopefully better than the lot they ran on last week. Corvette ran off course and hit a tree!
http://local.google.com/maps?f=q&hl=...&t=k&z=18&om=1
Old May 7, 2007 | 07:09 AM
  #351
markdaddio's Avatar
Well the lot was on the smaller size, but it was smooth. Suspension changes made it about perfect handling wise. Now it's time to add more power.
Results:
http://www.cartct.com/05-06-07.shtml
Old May 7, 2007 | 07:45 AM
  #352
PPI's Avatar
PPI
/\always nice when your slowest time is quickest of the day
Old May 7, 2007 | 07:46 AM
  #353
WarmPepsi's Avatar
Results:
LOL.
take it easy on the guys, goodness.
3+ second gap.
Old May 7, 2007 | 09:51 AM
  #354
markdaddio's Avatar
Originally Posted by WarmPepsi
LOL.
3+ second gap.
Actually, I was. I was still running pump gas tune @22 psi. Heading out to AMS next week to get an aem installed and tuned to the new evogreen turbo going on tonight.
Mark
Old May 7, 2007 | 09:54 AM
  #355
Tevenor's Avatar
Mark
Very nice indeed. Always fun to watch you run Mark! No matter how far back the rest of the field is. And we are usually a long ways back.
-Sean Caron
Was: 1996 Eagle Talon SM 21
Now: 2006 Evo IX SE
Old May 7, 2007 | 10:49 AM
  #356
WarmPepsi's Avatar
Mark
you're a bad, bad man.
Old May 7, 2007 | 02:12 PM
  #357
nick735's Avatar
Mark
Mark it was nice to meet you yesterday... I was the tall blond guy oogling over your car. The car looked great, and you had some very nice runs. Youll have to make it to a few of the fcscc events in plainfield. The lot is smoother and larger than carts old lot in bristol. It sshould give you a little more room to see the benefits of the new evogreen.
PS if you ever want a co driver let me know
Old May 7, 2007 | 09:52 PM
  #358
markdaddio's Avatar
Good meeting you also. It was a fun event, even though it was a tight course. Probably won't run again until may 26th at Englishtown. Good news is the evogreen is in. Will fire it up tomorrow in the am, and check for leaks.
Old May 8, 2007 | 01:24 PM
  #359
markdaddio's Avatar
All I can say is Wow. This turbo will work well. Ran it this morning with race gas in for safety, but still with the old pump gas tune, and the car pulls as hard in 2nd gear at 19psi as it did with the makinen turbo at 24psi on the same tune. Once past 5000 rpm, doesn't fall off as much either. Plus it was 15 degrees warmer on the green test. Can't wait to get out to AMS to get the AEM installed, and have Martin put a race gas tune to this. Should be awesome. Stay tuned.
Old May 10, 2007 | 04:25 AM
  #360
EVO8LTW's Avatar
How does spool-up/boost response feel in comparison to the TME?
