Autocross EVO - Street Modified Build
Yeah, that's the first time I've seen that on an EVO. Pretty common on Bimmers and Mustangs. . .
I don't know what caused it, but I think it is due to the very rough track. Lots of peaks and valleys.
Looks to me like a lack of suspension travel. If you don't have helper springs up front and you have really stiff springs (14K+), that could be the cause. Or it could just be that you're running the strut shorter than you need to with the helper springs. I ordered helpers for the rear of my car (12K) to get back some of my rear suspension travel. If I went to 14K+ in the front I think I'd need them up front too.
Looks like you hit a bump to me. Your rear looks like it is compressed to about the limit of rear travel.
And I def agree with Kevin about AWD cars picking up the inside front...doesn't help. I do think it is more common than people think though. I know my car does it now (14k front, no helper) and in the past (12k frt w/helper and more shock travel).
Another thing I just thought of. Right now the rear bar is on full soft. That could account for the outside rear corner compressing alot and raising the inside front also. . . Getting ready for a Detroit Region event this morn.
Runnig ProIndex class against some pretty tough competition. I'll let you know how we do.
EVOlutionary
EVOlutionary
If anyone is interested here's a little video from the NNJR event this last weekend that Daddio ran. Sorry, no actual video of Mark, difficult to get when you run in the same heat. His fast time was 45.0 (SM), mine (BSP) in the video is 46.1. There is also an STU video from the same event too.
http://holunfie.blogspot.com/
John
John
So the new turbo and aem setup seems to work great. Unfortunately, it seems that my front tires were going off, as I could not get the front end to bite. The car is up on stands now, and I am double checking everything to make sure something isn't out of wack from the 2000 mile round tripper out to AMS. The handling on the car was nothing at all like it had been the first 3 events out, so I am not sure yet what to make of it. There were two tight turnarounds, and it didn't seem that I had to wait for boost, so that is a good sign. I guess Devens will be a crap shoot, as I am not sure exactly what to expect. We will see.
I would agree. EVOlutionary's rear end looks awefully low possibly comprimizing the rear suspension travel.
On the other hand, if I can ever get my car to reliably lift the inside front wheel, I will be a happy camper....
Problem with lifting the inside front is the OEM and GSC center diffs are open. Combine it with a helical front diff and the result is lots of wheelspin. Helical Diffs require both tires on the ground to be really effective.
True. Now if you had a Cusco 1-way front LSD, alot of the power going to the inside wheel spin would be transferred first to the outside wheel, and then any wheel speed difference between the front and rear would be taken care of by either the VCU or ACD moving power to the rear.
