Help with ohlins clunking
Old Jun 23, 2007 | 12:00 AM
heeltoer's Avatar
Hi guys,
Need some help from folks with experience with ohlins. My driver side corner has recently been clunking at any speed when suspension is even slight compression.
After checking between the good front corner and the one with the clunk. I think I may have found a culprit. Refer to picture below.
http://tinypic.com/view.php?pic=6c64qdc
That top hat on the bad corner appears to be very loose where as on the other corner its much tighter. Here is a pic of the top mount for reference.
http://tinypic.com/view.php?pic=4kp7p55
Anyone know how to tighten this top hat or what other issues it might be?
Many thanks,
-yang
Old Jun 23, 2007 | 12:29 PM
SOLO2M3's Avatar
My right front Ohlin started clunking too.
Looking at the nut at the top of the strut under the hood, it had about 3-4 threads showing. Th left front had 10+ threads showing.
I used a battery powered impact (the same Dewalt that I change wheels with at events) to tighten it down. It's set to about 70 ft. lbs. The clunk went away for about 2 weeks but it came back. Tightened it again and 2 weeks later it came back. Used some red locktite on it and the clunk has been gone ever since.
Hope this helps.....................
Old Jun 23, 2007 | 02:13 PM
tsi90awd's Avatar
I've got Ohlins. I was at the track a couple of weeks ago and was checking some fasteners under the hood when I had some spare time. The top nuts as described by solo2m3 were a bit loose. They were easy to tighten up with an appropriate hex wrench and closed end wrench. These do seem to loosen up with time.
i plan to check these regularly now!
Old Jun 23, 2007 | 03:27 PM
mot's Avatar
mot
i thought my ohlins were clunking in the rear
i ended up having a broken sway bar mount from hotchkiss
total weaksauce
Old Jun 24, 2007 | 11:12 AM
chrisw's Avatar
total weaksauce
contact hotchkiss, they have excellent customer service and really stand by their product.
They can provide you with new mounts.
Old Jun 24, 2007 | 11:21 AM
heeltoer's Avatar
hey guys
thanks for the responses. Yeah it was the top nut that was had come loose. used a 17mm socket, anyone know the torque spec? I just hand tightened.
Thanks,
-heeltoer
Old Jun 24, 2007 | 11:37 AM
SOLO2M3's Avatar
Ohlins says 70 ft. lbs (or is lb. ft, I never get it right). Suggest locktite like I mentioned above.
Old Jun 26, 2007 | 10:37 AM
Eclipse2Lancer's Avatar
I have been having the same problem with K Sport coilovers on my Ralliart. I just carry a socket wrench in the car and tighten down when needed.
Pretty sure it is a byproduct of the MacPherson setup on the front. I never have a problem on the rears (multilink).
If I tighten too much, I get a spring clunk when turning the wheel at very slow (parking lot) speeds. Maybe the pillowball mount is binding and not completely turning at low speed? Need to check torque specs on the K Sports.
Think I will try the loctite on it soon.....good suggestion.
Old Jun 26, 2007 | 11:42 AM
DaWorstPlaya's Avatar
I don't know if using loctite is the correct solution for this particular applications. Aren't you supposed to use a nylock nut on the top instead? These nuts are known not to loosen up.
Old Jun 26, 2007 | 11:48 AM
Mine has a nylok nut, but they are still backing off after awhile. Maybe we need new nylok nuts?
Old Jun 26, 2007 | 11:51 AM
tsi90awd's Avatar
Maybe a better solution is to use a second nut as a jam nut. Not sure if there is enough thread exposed, though.
Old Jun 26, 2007 | 12:30 PM
WarmPepsi's Avatar
you never re-torque a nyloc nut.
always use new.
Old Jun 26, 2007 | 01:28 PM
always use new.
ah....makes sense. The nylon is now just threaded and not providing a real "lock". Will look for new.
Thanks for switching on the light.
Johns_EVO_IX_SE
Mar 19, 2012 10:45 PM
abazaba410
For Sale - Cars For Sale
27
Aug 7, 2008 05:03 AM
nrcooled
Apr 3, 2006 07:55 AM
