EVO Aerodynamics Review
Old Oct 6, 2014 | 08:26 AM
  #331
killerpenguin21's Avatar
is anything cut out of your trunk?
Old Oct 6, 2014 | 04:05 PM
  #332
GTABurnout's Avatar
Nope Stock GSR Trunk lid.
Old Oct 6, 2014 | 08:31 PM
  #333
kaj's Avatar
kaj
Maybe I'm glad I didn't jump through the hoops for a Kognition wing.
Old Oct 8, 2014 | 12:10 PM
  #334
Balrok's Avatar
Originally Posted by GTABurnout
Well one track day in to my use of my 68" Kognition trunk mount and I have bent the trunk. So far this wing took 12 weeks to get is not the best quality and it bent my trunk. But car feels super soild with the extra down force.
I have the 70" Kog, doing 150 on RA back straight all year, stock truck, stock mounting location, no bends or failures. To put it on a street car and expect it not to bend or brake things with 500+ lbs of downforce at speed is just misinformed. That goes for any decent wing. Why do you think most of the track cars have tons of mounts on the front splitter.
Old Oct 9, 2014 | 08:12 AM
  #335
GTABurnout's Avatar
Car is a gutted caged car with a stock trunk. After lookign at a few other cars running trunk mount wings I think my trunk is the same amount of bent as everyone else. I will need to grab a picture and I plan to reinforce it soon.
Old Oct 10, 2014 | 01:23 PM
  #336
SS RX7 r2's Avatar
Originally Posted by Tevenor
If you did that, I'd be all over it. I was already in the process of custom designing a wing-independent method to do a safety latch that braces to the trunk floor plan to help on both bow up and force down distribution. If you incorporated it as part of the mounting bracket, makes my life and probably a lot of others lives easier to distribute the downforce into the frame instead of across the deck lid.
You have a timeframe in mind for that bracket change? We talking 6 months or a year out?
New trunk bracket design should be out in about 2 weeks.
We're almost done working with an Evo X customer on a trunk mount that bolts to the stock trunk holes. Also will have a provision to tie into the Evo X's trunk hinge plate, for added support.
Old Oct 11, 2014 | 08:39 AM
  #337
GTABurnout's Avatar
tieing to the hinge plate is a great idea....
Old Oct 23, 2014 | 09:18 AM
  #338
I FINALLY got some data from aeromotions...although it's not terribly useful.
Old Oct 24, 2014 | 05:49 AM
  #339
SWOLN's Avatar
It is useless. At what AOA is that data? and how does it change as the AOA changes?
Old Oct 24, 2014 | 07:16 AM
  #340
Hiboost's Avatar
If I'm reading that right they are saying at "Max DF" or highest angle of attack setting (12 of 12) they are getting around 50 lbs of downforce @ 50 mph, 225 lbs @ 100 mph, and 525 lbs @ 150 mph.
The Drag at Max DF setting shows really minimal drag, so minimal that it's hard to believe it's less than 25 lbs @ 150 mph?
Then the AoA = 0 line shows how it's quite a bit less downforce with the wing flat.
This has me wanting to go to the drag strip and do back to back runs with the wing at 0 AoA and then compare it to the max setting to see how much MPH trap speed it penalizes you which can be roughly converted to WHP losses at various speeds.
Old Oct 24, 2014 | 07:45 AM
  #341
yeah chris, i believe your explanation is correct however i really wish the data points were labeled. I was told it is "real world" data which i take to mean that it is a plot of data right from the Winshear tunnel. at least it shows me level of drag which is my main concern and i can ALMOST compare it to other wings that i have actual numbers for.
you could also do us all a huge favor and just go out on the highway late at night and do some coast down testing....plllleeeaaassseeeee?
Old Oct 24, 2014 | 08:31 AM
  #342
SWOLN's Avatar
Hmm, good observations. How about placing some yarn to see when the air detaches? Try 13, 14, and 15 degrees to start?
Old Oct 27, 2014 | 11:05 AM
  #343
honda-guy's Avatar
do it Chris. i'd like to know how efficient my Aeromotion wing is
Old Oct 29, 2014 | 07:05 AM
  #344
Hiboost's Avatar
Coast down testing and yarn, could get interesting.
I can see about some testing if the weather clears up a bit as you would want close to zero wind as possible and no rain.
So basically for the coast down tests you want to compare minimum AoA time from 100 mph down to 50 mph in 6th gear (or neutral?) against having it at max AoA on the same stretch of road or similar?
The yarn test probably will show the wing flowing well at all angles since I now have a Gurney flap on the trailing edge of my Aeromotions wing but I can see how it compares.
Old Oct 29, 2014 | 07:33 AM
  #345
SWOLN's Avatar
For the yarn test the gurney flap on the wing should keep the air attached until 15 degrees or so. If you decide to go with the R.Module take the gurney off...
You should look at adding a small angled (I have to look up the spec) gurney on the trunk in the future, it will help the air stay attached even longer so maybe 16 or 17 degrees based on previous reading.
