EVO Aerodynamics Review
Old Dec 14, 2017 | 04:50 PM
  #736
griceiv's Avatar
Originally Posted by EVOlutionary
Good info/comparison. I believe the price of the laser stuff has come down to a reasonable amount lately. But yes probably still a fair amount more than the shock pots.
What at I am wondering - what's the difference between the data gained from each that may make one or the other more useful for testing/tuning aero and suspension setup? The laser directly measures the ride height of each of the 4 corners, but that's all it does right? The shock pots measures the shock travel, which can be mathed out to equate to a wheel height, which can be correlated to a ride height, correct?
shock pots measure suspension displacement, laser ride height sensors measure tire+suspension displacement. laser ride height by itself isn't super useful unless you know what component of that movement is due to the suspension. so the options are shock pots (stand alone) or shock pots with lasers.
Old Dec 14, 2017 | 05:02 PM
  #737
dave_evolvix's Avatar
I'm not sure exactly which is ideal for aero. Hoping for someone with real world experience to jump in. My one thought is if you're looking for load added to the suspension, using the spring rate as a known constant, determining force isn't too bad. Measuring ride height has some other factors I'd imagine, not sure if practically it matters or if it's easily compensated for.
Technically either can be used to measure the distance between two points. One could setup the laser system to read the shock travel, or the distance between the chassis and ground. Similarly, the linear pots may not be explicitly connected to measure shock travel, depends on the attachment point. I've seen cantilever setups in some FSAE blogs for example.
Old Dec 21, 2017 | 12:53 PM
  #738
I found this article from Evolution Dynamics, where they used linear pots to measure down-force. Seems that these sensors alone provided them usable data:
https://www.evodynamics.com/blogs/ne...mics-testing-1
Old May 4, 2019 | 01:29 PM
  #739
jedibow's Avatar
car is down for the summer, I know the summer here in AZ is the like winter in the non Hell climates... Will be re doing the flat floor hoping to incorporate some tunnels.
George
Old May 6, 2019 | 12:09 PM
  #740
jedibow's Avatar
After doing some thought, and research I was wondering everyones thoughts on a false floor, so basically a flat floor ran under the car, but separate from the body, with a gap between the car and top of the floor. The wheel wells and sides would vent above the false floor increasing pressure above, and the lower pressure below would cause the false floor to pull down on the car.
George
Old May 6, 2019 | 12:25 PM
  #741
George
@jedibow Absolutely a huge benefit. Ken Thwaits EvO has a full custom undertray complete w/NACA ducts. Theres pics of it just cant seem find where they are
EDIT. Found one of the pics here:
Old May 6, 2019 | 12:32 PM
  #742
Ayoustin's Avatar
George
Eh, creating pressure above the false floor means the pressure differential between the top and bottom of the car goes down. Are you thinking of doing this as a means around a "no flat underbody" ruling? Or just trying to think out of the box? If the later you're better off just making a flat underbody.
What you're proposing is the same as why you don't see lots of front wing setups combined with very large front splitters. You get a high pressure zone above the wing, a low pressure zone below the splitter, but the pressure zone between the wing and splitter work against the differential across the wing. It's not the case every time but most of the time that's the result.
Old May 9, 2019 | 09:17 PM
  #743
jedibow's Avatar
I already have a flat floor, so thinking outside the box mostly, saw this on the formula one cars about 10 years ago and thought it was interesting. I'm redoing the underbody aero over the summer as this is the winter for everywhere else when you live in Arizona.
George
Old May 9, 2019 | 09:19 PM
  #744
jedibow's Avatar
Also I'm being lazy and don't want to redo my rocker moldings LOL as I have gotten much better at composites, but.... That is a lot of work hahahaha
George
Old May 12, 2019 | 03:01 PM
  #745
Bee-Raddd's Avatar
The double floor concept will only work if u can create a pressure differential between the 2.
Honestly i havnt seen it on any of the top time attack cars yet and they are kind of at the epitomy of car aerodynamics especially when it comes to saloon cars. Kyle.Engineers has great youtube vids which could give you some good ideas to do with floors.
Old May 13, 2019 | 09:06 PM
  #746
jedibow's Avatar
He has very good videos, I have seen them all.
George
Old May 13, 2019 | 09:34 PM
  #747
V.8MR's Avatar
Yeah ayoustin mentioned him to me. I've watched quite a few of his videos. Hes also a pretty good wheel man.
richardjh
120
Oct 6, 2017 08:58 AM
TTBEvoX
Jan 6, 2017 06:33 AM
tmaddox
For Sale - Wheels / Tires
Oct 21, 2016 05:04 PM
superstock1986
Aug 8, 2016 05:58 AM
Liquid0401
For Sale - Cars For Sale
14
Apr 15, 2016 12:27 PM
