Wheel width of STU champions?
Old May 4, 2008 | 12:15 PM
Evo_Someday's Avatar
In reference to the 245 tire... can someone please tell me what wheel width and offset have the STU chamions had the best results with?
On a side note: I'm thinking about running the Enkei RPF1 17X8.5 -30 @ 15.5 pounds. Is this the hot ticket or is there a better option?
Thanks!
Old May 4, 2008 | 06:39 PM
SS RX7 r2's Avatar
Thanks!
AFAIK, 17x7.5 in '05 and '06, and 17x9? in '07. Paulson would know for sure.
The RPF1 is a good light wheel. If you go 17x9, they need spacers to clear the calipers. LMK if you need spacers, as I make custom 19mm ones for those wheels.
Old May 4, 2008 | 09:30 PM
coneracer30's Avatar
[QUOTE=SS RX7 r2;5623508]AFAIK, 17x7.5 in '05 and '06, and 17x9? in '07. Paulson would know for sure.
QUOTE]
Right in the money Rick. The 245 Yoks are nice and square on the 9's.
James
Old May 5, 2008 | 03:55 PM
Thanks for the info.
Old May 8, 2008 | 09:35 AM
I'm thinking about going with the 9" now. I heard that you really only NEED spacers for the front wheels to clear. However, is it typically best practice to put the spacers on all four wheels? How much $$ are the spacers?
Also, how does the tire fit the fender with that offset and spacer? Especially with coilovers and a little lowering. Will it fit fine? Rubbing?
I'm kinda looking for a setup that will be good for STU class and yet still streetable. Is this a realistic expectation?
Sorry for all the questions. I just want to know the details so I know what to expect. Thanks.
Old May 8, 2008 | 11:47 AM
redvolution's Avatar
Thanks!
RPF1s in 17x8.5 +30 do not weigh 15.5lbs. It's more like 16.9.
Old May 8, 2008 | 11:58 AM
SS RX7 r2's Avatar
Just spacers in the front to clear the bigger calipers.
Check H&R spacers for a typical price.
245/40-17 are a relatively small and short tire for the Evo's wheel well, so no rubbing anywhere.
* My RPF1s weigh 16.4 lbs
Old May 8, 2008 | 01:13 PM
Thank you. That all sounds good and exactly what I needed to know. I can buy with confidence.
As for the weight, I believe you, but am surprised because the vendor said they were a pound lighter http://www.enkei.com/RacingSeriesSpecs/RPF1.html
Shocking eh?
Construct
Jan 26, 2017 08:01 AM
SonicEvo
20
Jul 10, 2011 06:07 PM
JDMS60R
Jan 24, 2011 11:05 AM
delongedoug
Sep 9, 2008 08:58 AM
TSL Rich
Apr 8, 2008 06:25 AM
