Steering Angle Sensor vs Aftermarket Steering Wheel?
Somewhere in the back of my little brain I think I remember reading something about a component of the steering angle sensor being built into the back/hub of the OEM steering wheel. This means that when you install an aftermarket steering wheel you no longer have an SAS reference going to the various computers in the car. . .
Can anyone confirm or deny that this is true??? Thanks!!
EVOlutionary
EVOlutionary
Since the steering wheel sensor is an integral part of the ABS system, I would think that a failure of this sensor would trigger the ABS inop light. Well, I have an aftermarket wheel and my ABS works great.
So, my 2c.
So, my 2c.
Ah, good point. I don't have ABS so never thought about that. The only think I can think of that would go against that thought is if it defaulted to "straight ahead" and just always told the ABS computer the wheels were pointed straight. . .
I'm going to fish around and see if I can find the source where I read this . . .
Jarrod, the steering angle sensor remains on the steering column when the OEM wheel is removed. On the back side of the OEM wheel there are three holes near the center hub which allow three pins on the rotating portion of the angle sensor to engage the wheel. The three holes/pins are orientated so they can only engage in the proper position, as long as you put the wheel back on straight the angle sensor will be fine.
All the quality aftermarket steering wheel hubs I’ve seen have holes for the steering angle sensor so adding an aftermarket hub/wheel should not affect the ABS.
Thanks Kev! The 3 hole thing is what I read about. Good to see you on the forums. I hear you should have power galore this year!! I look forward to seeing your car out this spring!
I have a Splash hub, and it does it a bit differently, the clock spring mechanism is captured by a cutout in the hub at the bottom, so that's what causes the clock spring to rotate with the steering wheel.
Just a different way of achieving the same thing, but people might think that a hub that doesn't have 3 holes isn't going to operate properly with the steering angle sensor which isn't necessarily true.
we had to modify the hub to fit the steering wheel sensor.
We ended up cutting out a little piece of it. And painted to black, so it is basically invisible.
Works perfect and seamlessly.
make sure you will not turn or play with the sensors keep them on the original position. You can very easily damage them.
Than you have to buy a new one + recalibrate them. Also without the sensor the S-AWC is not working.
KillaJay
Jul 24, 2020 01:15 PM
EVOlutionary
Jul 18, 2013 08:53 PM
neogx
Lancer Troubleshooting
Nov 3, 2012 01:13 PM
MY08GSRX
Mar 12, 2009 09:33 PM
