CBRD Time Attack Testing- summit point
Old Aug 10, 2009 | 06:11 AM
CBRD's Avatar
Well,
we finally got her out on sunday for some private testing on the small jefferson circuit... The idea was to just shake the car down and make sure every system on the car was working well...
We had some small issues throughout the day... the main being a gearbox issue with the car not wanting to go into gear on upshifts.... especially 3rd to 4th.... we are going to make some fluid changes and bushing changes and see where that takes us...
The track is a small 1.2 mile driver ed track with a nice little carousel, some off camber transitions and short straights...
we started off just checking the brakes and power delivery.... The tial housing and custom intercooler setup worked brilliant... very progessive on throttle input...
all in all, we probably had about 6-7 undisturbed laps (aka without shift issues)... and about 25 laps in total.... we had an issue with a manifold fuel rail stand-off breaking mid-day... and we were able to have the manifold off in about 15 mins and had it rewelded and back on the car within an hour (thanks in part to Mark our tech and quick disconnect fittings)...
I then concentrated on small damper changes..... which made significant improvements.... our laptimes went from 1.01s to 58's in the first 3 lap test period... down to 54.4 at the end (all on the same set of ao48's) even with gearbox issues...
we then made some adjustments and changed our shortshifter... and put Myles in the car from Race Comp/GT worx, who is a great friend of mine and very well versed in these cars... promptly... after pitting in twice for tire temps and pressure adjustments... he got down into the high 55's.... Myles stated a slight improvement with the shifter change.. but still had issues shifting as the box got warm...
All in all, it was a fun day... I think the car is capable of a 51-52 second lap around the track on the A048s... which I believe is pretty fast (i think the track record by a Toyota Atlantic style car is a 48???)..... we also have some slicks to test later...
We now have a laundry list of things to address before our first official event some of those which include:
Different Front Brake Compound (we caught the fronts on fire)
Brake Cooling ducts
Shrouding around the oil cooler (we saw oil temps of 240 degrees, which drug the coolant temps up to 210ish, normally theyd run around 185)
and the big one, reworking the shifter setup and bushing assemblies...
The damping worked great on the Motons, although we need to control the springs a little more... so we will make some changes there also..
Overall, a sucessful test.. My first time back in a car on a track since late 2004.... and it came back pretty quick... although the car did feel quite heavy (2900lbs) and lacked grip compared to the LMP cars i drove... oh yeah..and way way too much power assist for my liking on the track even with about 6 degrees of pos. caster!
quick pic.. more high res and video coming this week
Thanks to everyone-
The CBRD Team
Advan
Myles from GT work and his buddy jon
Moton, Buschur, and many more!!!
CB
Old Aug 10, 2009 | 06:22 AM
grillpt's Avatar
Glad to hear she's out on track.
What clutch package are you guys running? Is this a high rpm lockout you guys are experiencing or just a reluctancy to up-shift? Either way, I know you'll get it straightened out...
I want to see pics of those brakes on fire...
Old Aug 10, 2009 | 06:58 AM
Balrok's Avatar
^ Finally!
Two q's - what brake combo were you using and what weight oil were you using?
Old Aug 10, 2009 | 07:01 AM
GTWORX.com's Avatar
Myles called me giggling like a school girl on the way back from the track.
He LOVED the car. Very fast.
- Andrew
Old Aug 10, 2009 | 07:48 AM
CBRD's Avatar
Originally Posted by Balrok
^ Finally!
using the brembo 6 piston monoblock front and 4 piston rear
DS3000 all around..
ill be leaving them at the rear and going to a PF pad up front...
it was just not enough for the track... we werent using hardly any rear brake..
15w-50 dominator amsoil... which may change also..
i think its pretty awesome we ran the car tuned on 93 octane
cb
Old Aug 10, 2009 | 07:54 AM
Robevo RS's Avatar
cool! great to hear you are back on track
Old Aug 10, 2009 | 07:56 AM
jid2's Avatar
That's bizarre with the shifting. Have you tried using the stock shift lever, I've found every short shifter to be worse than stock.
Should be fun to get the splitter and diffuser on there and out on a faster track, and running some E85!
Old Aug 10, 2009 | 08:08 AM
Smike's Avatar
Great to hear GTWorx stopped in too!
Old Aug 10, 2009 | 08:38 AM
Balrok's Avatar
DS3000 all around..
cb
Cool, ya i've been running on the 93 tune forever, and set a few pads on fire, especially at Barber. Keep up the great efforts Chad
Old Aug 10, 2009 | 08:58 AM
stealthyevoviii's Avatar
Congrats finally getting the car out on the track and great lap times as well
Old Aug 10, 2009 | 12:17 PM
CBRD's Avatar
working now trying to get some custom PF pads done some repackaging of our oil cooler and changing fluids
cb
Old Aug 10, 2009 | 12:24 PM
nils's Avatar
shake those bugs out boys.... good to see the car finally on track and bless us with incar video sometime pls!
Old Aug 10, 2009 | 12:46 PM
meanmud's Avatar
cb
Hopefully you can make some of the events before the end of the season
Old Aug 10, 2009 | 01:00 PM
zbomb's Avatar
Nice to see it made some turns in anger. I have little doubt this car will turn into a force.
Sharif@Forged's Avatar
Congratultions on finally get it up and running, and out on track. Must feel like a great accomplishment. I am looking forward to seeing this car in NJ in a few weeks.
