Advice on track time
Old Apr 27, 2010 | 09:23 AM
  #46
rcheung's Avatar
Originally Posted by justboosted02
just lowing your boost probably isn't a good idea, it can move you into load cells that you were'nt necessarily tuned for. Its much better to just spike your tank with 5 gallons of 100 oct
My tuner also told me to put a couple gallons of race fuel when I go to the track.
Old Apr 27, 2010 | 09:30 AM
  #47
AlwaysinBoost's Avatar
a couple gallons of high octain is never a bad idea, but unless your tuner is a complete and total ra-tard, you should have NO problem turning the boost down as low as you like. heck, you could run off the wastegate and be safe.
Old Apr 27, 2010 | 10:04 AM
  #48
justboosted02's Avatar
Originally Posted by EriCS
I will have to talk to my tuner and see if its a bad idea. Running at full boost is too much as I am at 400whp on stock Turbo right now. I will maybe have him give me a second map.
that is a good idea, its not that you absolutely need a second map for less boost, but you should at least log it at the lower boost setting to make sure everything is still good/ nothing funky going on
Old Apr 27, 2010 | 02:00 PM
  #49
meanmud's Avatar
Enuff talk - Time to shut up and play your guitar! Just a little Zappa thing......
Yup, a little race gas never hurts, brake fluid good and enough pad, then you'll know next time what you need to do.
Old Apr 27, 2010 | 04:16 PM
  #50
xtnct's Avatar
Like I always say, the best way to mod is to let the car tell what it wants. Take a stock car (or what you have) and use it. If the car will want something different it will tell you, if it will want different pads, it will tell you, If it will want different tires it will tell you. Also, this is the most productive and cheapest way to mod + you will learn a lot more + you will become a better driver because of it.
I am willing to bet that for a first timer, the car will say: That's all you got? Bring it on.
And yes, even if you have 500hp and stock pads, the story will be the same.
Old Apr 27, 2010 | 04:42 PM
  #51
EriCS's Avatar
Yea know your probably 100% correct! I would still like to probably be set up before I get there so I know I will pass tech inspection. My pads are low and my rears have camber wear otherwise a Honda Civic would have been sufficient. I am only concerned about doing things properly and safely!
Old Apr 27, 2010 | 05:19 PM
  #52
xtnct's Avatar
Yes, as others have stated, make sure you have at least 1/2 pad thickness left on the pads or more and that the rotors are not close to their min thickness. Fresh fluid & flush and you are good to go!
Old Apr 27, 2010 | 05:42 PM
  #53
Laxman's Avatar
If you are running the stock 6sp, think about changing out the fluid after the event. Definitely change it before the next track day weekend.
GotKT?
May 19, 2015 06:10 AM
MyFirstCarEvo
Evo X How Tos / Installations
Aug 30, 2013 09:29 AM
catman78
12
Mar 27, 2012 05:15 PM
Smike
May 24, 2011 04:52 AM
Smike
Apr 22, 2011 05:20 AM
