Carbotech Pads for Evo X
I have been doing HPDE's since 2004 and on June 11 I will be doing my first in an Evo X. I run Carbotech XP10's front and rear on my Miata with 225 width Hoosiers and have had great success with them.
I am looking to get a set of Carbotech Pads for the Evo X and I need some advice on the compounds. From what I understand the XP12's should be fine (>3200lbs on street tires) but should I run these front and rear?
The car is equipped with 265 width Kumho Ecstas.
Ya should be fine. I know of several Evo's running XP 12's and a few on 16's with full mods. 8's wouldn't last long with such power/weight. The only time you get into splitting compounds is if you were running super torque like 16's, DTC70, ST47, etc up front, then I wouldn't put 16's in the back, but with the 12's you should be aight.
I think 10's up front and 8's out back would be fine. Not saying you shouldn't run the 12's/10's, just that it might be a little overkill for those tires. Either way, you'll be happy I'm sure.
I will be going back to the 10's all around because they're a touch cheaper than the 12's and seem to last a good bit longer. I went thru about 2/3's of my XP12s in 3 track days vs. the 6 days I usually get out of a set of 10's. YMMV
I should have put some brake ducting in. After 15 minutes the fluid boiled (Motul 600) and turned the Brembos into Blackbos. I flushed the fluid for Motul 660 and took it easy on the brakes for the next few sessions and they held up fine. It was my roommates car and luckily he thinks the Blackbos look gangster so he wasn't too mad. Also he got the itch for track days and will be joining me in August for a track day at Sebring, but he'll be driving this time.
WWJPD
Aug 26, 2015 11:39 AM
Buschur_TSI
13
Jul 29, 2011 06:00 AM
JDavenport
14
Sep 7, 2010 01:47 PM
