Evo viii fuel starvation
Old Sep 15, 2012 | 07:14 PM
piper971's Avatar
I have been autocrossing this car since new in 03, last tune was 4 years ago. Last upgrade was a new rear diff a few months ago.
Just recently, last month or so, i am experiencing starvation in 90 degree left handers. I usually keep the car at a 1/4 tank. I have searched the forumns, but most post are about the X.
I changed the fuel pump, replaced with another wally hp, and i am still having he same problem.
Has anyone else experienced this ith their 8 or 9?
Old Sep 15, 2012 | 07:26 PM
ezzey's Avatar
umm, fill up to 1/2 tank
/thread
Old Sep 15, 2012 | 07:29 PM
piper971's Avatar
I am trying to figure out, why it just started after 9 years.
Old Sep 15, 2012 | 08:24 PM
FilthyEvo's Avatar
Changed the fuel filter recently?
Old Sep 16, 2012 | 09:41 AM
piper971's Avatar
Yes i changed the filter at the same time i changed the pump.
Old Sep 16, 2012 | 11:18 AM
FilthyEvo's Avatar
Have your injectors flow tested/cleaned? But if it's only happening when racing at 1/4 tank, that wouldn't make sense.
Hmm.
Old Sep 16, 2012 | 11:55 AM
KevinD's Avatar
What tires are you running? Also, do you have a wideband on the car you can log with? Evo 8s are hard to fuel starve. We run em pretty empty with Hoosiers and still don't have problems until its less then a 1/8 usually. Usually we start sessions at 1/2 tank though.
Old Sep 16, 2012 | 12:32 PM
Wonder if it could be that secondary low volume pump in the right saddle tank?
Has anyone ever experienced a failure w/that part?
Just a .02 thought
Old Sep 16, 2012 | 01:00 PM
piper971's Avatar
Running hoosiers as well. I am stumped because i have never had this problem in 9 years. My next step is checking the filter on the passenger side, and if thats fine, then time to trouble shoot wiring.
Old Sep 20, 2012 | 05:55 AM
justboosted02's Avatar
what BOV/BPV do you use?
i had a very similar problem to this before, ended up being that my Tial QR bov was hanging up in tight right hand corners causing all sorts of issues.
highly doubt its anything in your tank (pump,filter, or actual fuel starvation)
Old Sep 20, 2012 | 08:29 AM
FilthyEvo's Avatar
Oh, you think it's a surge causing the problem? Makes sense.
I run a crushed 1G DSM BOV and I have no surging issues.
Old Sep 22, 2012 | 06:44 PM
piper971's Avatar
May have been a loose connector. I have an auto-x next week, i will see what happens, and update you guys.
RoryE4
Dec 22, 2015 10:46 AM
Grimgrak
May 1, 2015 06:05 PM
Snakes709
Apr 30, 2012 09:43 PM
F0RSAKEN
Jun 28, 2011 06:19 PM
