Anyone mount/balance own tires?
So for us track fiends, changing tires 1-3 times a season is the norm. Out here in Las Vegas every shop charges 20-25$ a tire. This is obviously getting costly. The idea of adding 80-100$ to do a set of tires just bothers me. Considering it's about 20-30 minutes of the shops labor. Was thinking about buying the equipment my self(maybe splitting it with 3-4 people) to see if it's worth it in the long run. I also see some manual changers(harbor freight) that are cheap but watched some videos and didn't like it at all. Anyone find the best cheapest way of handling this issue? Or should I stop complaining and just pony up the doe
I remember when I was a kid jumping on tyres for my old man trying to break the seal, he used to have a collection of big levers and changed his own tyres, I wonder If you did that to a modern tyre would it take the stretching with a 3 foot lever to get it on a rim lol
I have considered this many times. With 4 cars, 3 with winter and summer tires and autocrossing the Evo, the pay back is not bad. ~$100 per tire change and a about $2000 for the equipment = 20 tire changes. Probably about 5 years for me on my own, but I could also charge people to use it.
Problem I have is where to put it haha.
I'm glad I'm not the only one. There is about 75 local autocross guys that don't miss an event. No one would go anywhere else if they are getting it for 30-40$ cheaper. May have to pull the trigger. One worry is to get something of poor quality and costly at the end
Changers are cheap. Balancers are whats expensive. And I would be weary of buying a used balancer, when parts in them fail, it can get expensive real quick. A decent basic changer from coats with a nylon duck head is all you need for the changer. Find one used for <$2k...
I'm glad I know guys at discount tire from when I worked there. Good tire equipment is expensive...lol
Good advice on the balancer, since we are on the topic...
I'm not really familiar with tire changers/balancers.
Is there certain features that are a must?
What's the difference between the expensive ones and the cheap ones (other than quality)?
Any advice would be awesome.
But, I'm used to being able to fully install (unbolt, changem air, balance, bolt on, torque) 4 tires on a car with 16"steelies in 15 minutes by myself. So it bugs me when I'm using use a crappy changer lol.
when i started to run hoosier, i needed to flip them after two events or the outer edge would cord. that got expensive really quick, since it was like 10 times a years. so i got a used changer for less than $1k. it paid for itself the after the first year. i wanted to get a balancer also, but i dont have enough room in my garage to keep two big machine. so i figure id try harbor freight bubble balancer first and see how it works. it works pretty well, obviously not perfect like a true balancer. but good enough to drive on track. even if you have perfectly balanced wheel, you'll end up with a ball of tire worms at the end of the day inside the wheels to throw off the balance anyways.
as for autox, most people i know who only autox dont even bother to balance if they don't use the tires on street.
