Trans fluid when using Clutch front diff
Old Sep 9, 2019 | 08:00 PM
Bee-Raddd's Avatar
The front diff is inside the tcase, but is sealed off from sharing the gear oil with the tcase. It receives oil from the trans through a fluid transfer port. The front diff doesn't have fill/drain plugs because it's sealed off inside the tcase. It gets fluid delivered to it from the trans, so whatever goes in the trans goes into the front diff.
Do not put trans fluid into the tcase. You will wipe out the ring and pinions gears in very short order.
I always put 75w140 in both and ive never had issues...
Old Sep 9, 2019 | 10:01 PM
LetsGetThisDone's Avatar
Your dog box calls for a different fluid than a synchro box. And you're still likely using a fluid that doesn't have a friction modifier, otherwise the clutch front diff wouldn't do much.
Old Sep 10, 2019 | 10:49 AM
kikiturbo's Avatar
yeah, dog box is compatible with plate front diff.... problem is with synchro box and plate front diff.. I am modifying my transfer so that the front diff uses the transfer box oil (which is LS oil) and gearbox is kept separate from it..
Old Sep 10, 2019 | 11:45 AM
You literally don't want to use LS oil. LS oil reduces the locking action of the diff. Why would you want to do that?
NY Evo
Apr 12, 2015 05:28 AM
trboboost91
Jul 22, 2012 06:58 AM
MULLDOG
Mar 31, 2010 12:38 PM
Ty-Evo8
11
Aug 30, 2004 05:08 PM
