Alignment Question - Suspension Gurus
Old Nov 20, 2016 | 07:15 PM
alleggerita's Avatar
Given that the front axle on an AWD vehicle is more similar to a FWD than RWD, the following probably applies:
Also there's a difference between static and dynamic toe. Especially on a frontwheel-driver you see this happening.
The same goes for a rearwheel-driver with independent suspension left and rear.
What happens is that when torque is applied ; The driven wheels pull themselves forward trying to toe-in.
Now it depents on the construction of the suspension how much the toe-in will increase.
On streetcars this effect is a lot bigger than on race cars as they use softer rubber bushings in the suspension-joints.
from: http://en.intraxracing.nl/techniek/c...toe-intoe-out/
As such, with slight static toe-out you will likely run closer to 0 dynamic toe than you are with static 0 toe. Also you will reduce moving from toe-in under spring extension/decompression to toe out under spring compression that should benefit decreased bumpsteer and potentially tire wear?
Just some thoughts ....
Old Nov 20, 2016 | 08:06 PM
kyoo's Avatar
does our front suspension toe in under compression? our rear suspension toes out correct?
Old Nov 20, 2016 | 08:08 PM
I think toe-out in front and toe-in in rear under compression.
Old Nov 20, 2016 | 08:09 PM
kyoo's Avatar
i thought it toes out in the rear, and that's why we run a small amount of toe-in in the rear?
Old Nov 21, 2016 | 08:43 AM
03whitegsr's Avatar
Pretty sure it toes in both front and rear with travel. That's why the rear bump steer correction bushing lengthens the toe arm.
If you want a car that spins though, make it toe out in the rear with travel.
As for the original post though, I've ran -2.5* and 1/32"-1/16" toe out for years on different cars and never really had any issue with shoulder wear. Could be some truth to it.
Anything more then 1/16" though made the car want to wander too much for my likings and made it nervous feeling in the rain.
Smogrunner
27
Jul 6, 2012 04:35 PM
05blue8
Feb 14, 2008 06:57 PM
MICLOIV
Jun 19, 2006 07:43 PM
SoR
Jan 14, 2006 05:23 PM
KazzEvo8
Aug 10, 2004 05:27 PM
