Post your competition suspension set ups here!
Old Jul 15, 2023 | 07:52 PM
  #151
MrAWD's Avatar
Originally Posted by kyoo
lol yea after run 2 i always sprayed my front tires down
On a hot day, I spray them after every run!
Old Jul 15, 2023 | 08:20 PM
  #152
LetsGetThisDone's Avatar
Originally Posted by Dallas J
You don’t autox but you also claim ax doesn’t put as much heat in the tires…. Yeah, no.
AX builds a ton of heat because it’s 60sec of max aggression with little wind and then just sit and heat soak. We do need tires to work cold, but that doesn’t mean that heat isn’t a constant concern.
We cool tires after even first runs to make sure by last runs they aren’t so hot they grease up.
Maybe where you run is different. But my region we have about 15-20 minutes between runs. So everything cools off for the most part.
Old Jul 15, 2023 | 10:19 PM
  #153
kaj's Avatar
kaj
Wow. We basically hot lap.
Old Jul 15, 2023 | 10:50 PM
  #154
Yeah. It's why I never go. Takes a 6:30am-5pm day to get your 7-8 runs in, as well as working the course for 3-4 hours. It's painfully painful.
Old Jul 16, 2023 | 12:42 PM
  #155
ViciousLSD's Avatar
track day or autox day, its all just a few seconds of managing turns
3-4 hrs working the course is bad! 1hr max over here. in some clubs we can even buy no-work assignments
Old Jul 16, 2023 | 01:05 PM
  #156
kaj's Avatar
kaj
Oh, hell no. We were usually done by 1pm or so. Autocross is not something I would want to do all day. Being a half day long event was part of what made acceptable for me.
Old Jul 16, 2023 | 02:53 PM
  #157
Dallas J's Avatar
Veteran: Army
Yep, half day long and Im chief of tech so I just work the morning.
Old Jul 16, 2023 | 03:19 PM
  #158
kaj's Avatar
kaj
Genius! Had I made AX a long-term deal, I would have DEFINITELY fought for that tech spot hahaha.
Old Jul 17, 2023 | 06:37 AM
  #159
kyoo's Avatar
i used to work registration in the mornings, and we knew ahead of time what class runs what heat. sometimes i'd be done before lunch, lmao.
Old Jul 19, 2023 | 08:27 AM
  #160
kyoo's Avatar
found my squeak. not endlinks, not sway bar bushing greasing, both of which i replaced, but... the makeshift battery tie down that was drilled through the trunk floor on one side was getting loose and the hook was rubbing or moving around or something. caused quite the racket.
i signed up for a ny autocross in a few weeks - will be my first in the area, first in a while. i took a look at the site and it's much, much smaller than what i'm used to. i may set the sway bar on it's most oversteer-y setting to help the car turn around some of the tight stuff
Old Jul 19, 2023 | 08:56 AM
  #161
ViciousLSD's Avatar
which site is that? you need to do the Metlife Stadium with NNJR
Old Jul 19, 2023 | 09:15 AM
  #162
kyoo's Avatar
NASSAU COLISEUM LOT #2 - looks tiny, tight, and short
JONES BEACH LOT #3 - looks pretty good.
Old Jul 19, 2023 | 10:49 AM
  #163
ViciousLSD's Avatar
I hope they're better now. In the boroughs i think the best site is Orchard Beach, Bronx. Not sure if they still run there.
have fun
Old Aug 16, 2023 | 09:54 AM
  #164
CaptainSquirts's Avatar
I searched around on the forums but, I picked up a set of FA pro 2. From searching, I read to get the external canisters inside the trunk is you gotta drill a hole at the bottom of the trunk to get them in? Is that the only option? Did verify with fortune auto that if you do disconnect the external reservoir it does compromise it.
Old Aug 16, 2023 | 10:12 AM
  #165
ViciousLSD's Avatar
what about the hole on the adjustable camber plates?
