So I did an "endurance autocross" this last weekend on a kart track with some interesting results.
The route has been run for 46 years and has a history of records continuously updated as records of this event are broken. First of all, the results are I did beat the old Street Mod Record set by a friend who had a solid and tough to be by any normal car record, but I dropped the 3:59 record down to 3:46. Seems appropriate since I do have the current and previous national champion car and its better this year BY FAR with fixed diffs and a few changes. Im of course hunting for a track record set by a B-mod car (D-sport racer if you arent familiar with B-mod that weighs ~1000lbs with usually a 1000cc motorcycle motor) but it was a bit out of reach at 3.42.
Car issues...
The most prominent being brakes. The Wilwood SL6R and DS2500 just wasnt up to the task and we (wife and I) had to baby them to make sure they didnt completely fall away in the 5 laps. Sitting in the garage now the pedal is still fully mush even though right before the event they were flushed with Motul RB600. I knew the brakes were going to be weak but at least they never fully gave up with conservation in the 2 heavy brake zones. Im working on the real long term solution to autox/track brakes now (thanks @Balrok for getting them here) with Aero6 calipers, carbotech XT-10 pads, and my old rotors.
Next issue is coolant... We were filling and pushing a little extra into the overflow both days. Not something we ever see in normal AutoX but the heat of the day and longer sessions started to shows something isnt 100% right. Keeping an eye on things it seemed to get to a point and hold and the next morning sucked things back from the res. I think my original radiator cap wasnt letting pressure build or my generic mix of antifreeze/water was inadequate for what we were doing. I checked today with an open radiator cap while idling to warm up that we didnt push air into the system via a headgasket and that all looked good.
Now, to test this fix things for a test this weekend preparing for a little even down in texas next month
Car issues...
I'm with you. I bought a G4x fury and it's a very familiar/similar interface to other aftermarket ECUs......it's not Motec level but I'm not sure what's bad about it? Available online resources and customer support is great. I was afraid of using emtron or ecumasters because it felt more foreign and I wasn't sure about the support.
Has anyone done any recent research on turbos? I'm trying to decide what turbo to go with for my 2.2 build. I will probably need two turbos...one for the shorter tracks that I have around me...and a larger ones like Road Atlanta or equivalent. Typically the EFR's still have a lot of love, but I've been looking at the G-Series. Thoughts?
Car issues...
Car issues...
Filling the reservoir on extended sessions is normal. For track days, I make sure my reservoir is empty, and leave about an inch of room in the radiator for expansion. Pretty much the same thing you do on a dirt bike because they don't have an expansion/overflow tank. The over flow line just drains to the ground, so even if you fill the rad up it just bleeds off the excess as it warms up.
One day, I'll step up to some sexy brakes and shave the weight.
Quick question for you guys. Looking for a cheap track tire for my Cobalt. Not shooting for best lap times but more of best bang for the buck and something that will last. I have it narrowed down the the Falken 615K+ or Nitto NT05. I have experience with the 615 and find it to be a good budget tire but havent run Nittos besides the NT01 on my Bug. Any input would be great!
new product from red line oil btw - https://www.redlineoil.com/supercool-with-waterwetter
solid looking stuff. Me likey. Nice find!
