Old Apr 8, 2021 | 06:35 AM
  #3016
kyoo's Avatar
Originally Posted by Lumpy Sticks
Did yours eventually turn blue? Mine did. Thinking mine aren't far behind yours.
i dont recall as far as color but it looks like you've got plenty of tread still
Old Apr 8, 2021 | 06:53 AM
  #3017
Balrok's Avatar
Thats lack of camber usually. Overheating the outside patch like that.
Old Apr 8, 2021 | 07:24 AM
  #3018
Dallas J's Avatar
Veteran: Army
Also keeping the wheel turned when understeering. When understeering if you steer more trying to get the car to turn or just leave it at that state of pushing it will roll over that edge and cook it. Its critical to un-steer back to a reasonable slip angle.
Old Apr 8, 2021 | 07:28 AM
  #3019
Ayoustin's Avatar
I'm getting some quotes for batches of camber and toe locks to be made.
The camber locks work for any arm, but mainly intended for use with the stock arm, they allow 7 different camber settings and eliminate the stock eccentric hardware so no worries about slipping bolts anymore. I test fit them on my car and they allow the full use of the entire slot that exists in the subframe.
The toe locks are only for aftermarket arms. They only have one position and are meant to eliminate any slipping of eccentrics used with the stock hardware. Due to the geometry of the slot on the chassis for the toe adjustment it's not really possible to make an adjustable lock like is possible with the camber.
All locks will come with class 10.9 plated hardware and locking nuts. More details to come when I have some inventory built up.
Old Apr 8, 2021 | 08:41 AM
  #3020
kyoo's Avatar
sorry to rehash this:
Amazon Amazon
Plug this into our Evo's obd2 for power & data, turn on at track, win? Come home and overlay with racerender for video syncing (not paying 1k for a **** camera)
nvm... looks like the older evo's aren't supported
Old Apr 8, 2021 | 08:53 AM
  #3021
Ayoustin's Avatar
Yea, the DL doesn't work because there's no CAN bus on the CT9A evos.
Old Apr 8, 2021 | 09:31 AM
  #3022
Lumpy Sticks's Avatar
5 Year Member
Nah, they are done. The inside of the tire is past the wear bars.
I am maxed out at 1.7° in the rear. 2.7° up front.
Yep, that is most likely what did it. Car loves to plow.
Old Apr 8, 2021 | 09:43 AM
  #3023
kyoo's Avatar
yeesh no wonder. im -3.5 front and -2.5 rear, with about 5.5deg of caster in the front
Old Apr 8, 2021 | 09:54 AM
  #3024
kaj's Avatar
kaj
How are finer adjustments made?
Also, am I still able to get a splitter template from you? I've brought it up so many times, I kinda feel like I'm just bugging or not taking a hint, at this point
Old Apr 8, 2021 | 09:56 AM
  #3025
Dallas J's Avatar
Veteran: Army
And realistically you could use another degree up front and 1/2 in the rear still.
Look at touring cars running waaay more camber, Ive seen upwards of 5deg in some cars. I cant speak to the specifics of their setups but they are certainly better prepped than us being professional teams.
I run -4/-3 and ~9deg caster. I could probably stand to run another .25 all around. On stock uprights, -4.5 was still probably not enough.
Old Apr 8, 2021 | 09:58 AM
  #3026
kyoo's Avatar
yea i dont even think i can get there on the parts i've currently got lol.
we should all just make/join a slack channel at this point
Old Apr 8, 2021 | 10:48 AM
  #3027
Ayoustin's Avatar
Not sure what you mean by finer adjustments but the way the locks work is there are 5 settings on one hole: 1- far left, 2 - halfway between far left and middle, 3 - middle, 4 - halfway between far right and middle, 5- middle.
Then there are 2 adjustments on the second hole (there might be 2 more that I didn't measure but need to double check). Those adjustments land between (2 and 3) and (3 and 4). I did some measuring on my car at different settings and each setting is around 0.5*. If you need to get more granular than that you can adjust the ride height by a fraction of an inch to get your desired camber but that's kind of splitting hairs. The price to pay for no slipping eccentrics is a loss in resolution of adjustment.
Yes, sorry I don't mean mean to keep blowing you off on the splitter stuff, I've been super overloaded trying to balance the day job, side business, getting my car back together, prepping other cars and trying to keep something of a social life haha. I'm setting up the template to be universal so one template will cover everybody, it'll include everything, you just have to cut out what features you want and trace the line at the extension length you want. Shoot me a PM with what front bumper you're using as that's the only thing that will differ between templates.
Old Apr 8, 2021 | 12:04 PM
  #3028
kaj's Avatar
kaj
We're about to reach street sweeper status.
Ah, didn't realize those allowed that small of an increment change. That's prefect. Count me in!
I figured you've been busy, no worries, dude! PM sent.
Old Apr 8, 2021 | 05:45 PM
  #3029
kyoo's Avatar
is anyone interested in a seat at ncm this weekend (4/11)?
Old Apr 8, 2021 | 07:02 PM
  #3030
Balrok's Avatar
You can't get tires?
