Old Apr 21, 2019 | 04:07 PM
  #511
211Ratsbud's Avatar
Originally Posted by Construct
This video of Robert Thorne's anti-lag system with overlaid gauges is fascinating:
Now who's going to be the first Evo owner to try the external combustion chamber anti-lag system?
I had a pretty compelling fresh air system development for some time. I used the maf hz to compare airflow during active and inactive
Old Apr 23, 2019 | 04:42 PM
  #512
Hoojan's Avatar
Originally Posted by Dallas J
An ASP evo needs around 4-4.5 deg of front camber and 2.5-3deg of rear camber.
I cant seem to get anymore than -4.5 up front. The bolts are maxed out along with the camber plates.... What are you guys doing to get so much more camber?
Old Apr 23, 2019 | 06:26 PM
  #513
kaj's Avatar
kaj
How much do you need???
Old Apr 23, 2019 | 08:13 PM
  #514
Ayoustin's Avatar
He's probably running on cement. Cement usually requires another 1-2° vs pavement due to the increased grip it provides.
Old Apr 23, 2019 | 09:01 PM
  #515
Hoojan's Avatar
I am running on concrete. Was hoping for another degree but am not sure where to get it...
Old Apr 23, 2019 | 09:32 PM
  #516
kaj's Avatar
kaj
That's impressive!
Old Apr 24, 2019 | 05:27 AM
  #517
MrAWD's Avatar
Did you check with Dallas...he might have some left...
Old Apr 24, 2019 | 11:22 AM
  #518
Bee-Raddd's Avatar
i have dallas offset tophats and i have huge offset bolt spacers in my struts and i can only get 4.5deg max.
Old Apr 24, 2019 | 06:37 PM
  #519
griceiv's Avatar
well I can't give away all the secrets.
...slot the strut holes a little bit.
Old Apr 26, 2019 | 12:55 PM
  #520
Hoojan's Avatar
Appreciate it!!
Can we run an aftermarket eccentric in the struts? (in ASP)
Old Apr 26, 2019 | 01:08 PM
  #521
MrAWD's Avatar
Appreciate it!!
Yes, all of it is good!
Old Apr 27, 2019 | 07:58 AM
  #522
Balrok's Avatar
That's a good idea, pick a spec length to slot them, and then Dallas or someone make the locking insert kinda like ProAwesome had for the stock slot.
Old Apr 27, 2019 | 08:22 AM
  #523
Hoojan's Avatar
Any recommendations for which brand is the best?
Old Apr 27, 2019 | 10:07 AM
  #524
Ayoustin's Avatar
No insert needed, you don't need to make a massive slot. Slotting the strut mounting holes is also a factory procedure from BMW on a lot of their cars if the car can't be brought into spec for some reason.
Old Apr 28, 2019 | 04:37 PM
  #525
Bee-Raddd's Avatar
only thing with slotting the hole is it will move over time esp if ur bashing kerbs etc.
I have offset inserts in mine. have 3 different ones i can swap in and out for different camber. this way because they are a round hole theres no chance of it moving like an eccentric or slotted hole can.
On another note u lot must be getting ready to start racing? whos doing what?
