Old Jun 15, 2019 | 01:27 PM
  #601
kyoo's Avatar
Originally Posted by kaj
I think my EGR is disabled in the tune..? I can't remember for sure and it's locked, so I can't look at it. But, I can't think of why it would be a problem, even on a stock ROM. Unless the valve has a sensor and looks for flow during startup/EGR use....?
the egr doesn't still "try" to work? i guess that's the normal case when it's off and closed anyway
Old Jun 15, 2019 | 01:38 PM
  #602
kaj's Avatar
kaj
I'm sure it opens, but that's fine. As far as I know, anyway.
Old Jun 15, 2019 | 02:45 PM
  #603
V.8MR's Avatar
If you pull all the parts, and disable in Tephra, then no it does not function at all. Am I missing something?
Old Jun 15, 2019 | 02:47 PM
  #604
kaj's Avatar
kaj
In Kalifornia, we can't remove the parts.
Old Jun 15, 2019 | 02:53 PM
  #605
Ayoustin's Avatar
So, who was fabbing the Alumalite splitters? Any updates?
That be me. Trying to tie up the last of the details this coming week. Will make a post in that thread in the next couple days.
  #606
V.8MR's Avatar
In that case, if you disable in tephra and install the block-off you should be good.
Old Jun 15, 2019 | 03:26 PM
  #607
LetsGetThisDone's Avatar
Its all disabled in your tune. Just block it off and go.
Old Jun 15, 2019 | 06:39 PM
  #608
Bee-Raddd's Avatar
Originally Posted by razorlab
The big end of the rod. The bearings.
yep big end rod bearings. Do them every season. they are usually beginning to go pretty average when i pull them out. Def wouldnt go more than a season on a set.
Old Jun 16, 2019 | 12:37 PM
  #609
kaj's Avatar
kaj
Eek. Yah. I'll stick with low WHP and the stock shortblock.
Old Jun 16, 2019 | 01:12 PM
  #610
kikiturbo's Avatar
Take a look at a stock WHP evo's first main bearing and you will be shocked then...
Old Jun 16, 2019 | 01:29 PM
  #611
kaj's Avatar
kaj
That's fine, as long as it lasts even close to as many miles as my last one.
Old Jun 16, 2019 | 02:45 PM
  #612
Bee-Raddd's Avatar
yea i wudn be so secure haha. ive always changed big end bearings even when my engine was low power. its the weak point of the 4g motor esp if ur wet sump and its cheap insurance to just swap em annually
Old Jun 16, 2019 | 02:50 PM
  #613
kaj's Avatar
kaj
My last short block went 130k miles. I drive about 3k per year. I should be good for the life of the car.
If I had to start swapping bearings every year (at my per level) I'd ditch the hunk of junk and go with another platform.
Old Jun 16, 2019 | 07:29 PM
  #614
kyoo's Avatar
txtx all
Old Jun 17, 2019 | 12:08 PM
  #615
Bee-Raddd's Avatar
Sounds like u need to drive harder hahaha
