Old Jun 28, 2024 | 06:36 AM
  #6226
LetsGetThisDone's Avatar
The easiest way to do it is put the belt on. Then you now disregard the timing mark on the cogged part of the gear, and instead line up the timing mark on the center portion with the mark on the valve cover.
Old Jun 28, 2024 | 09:10 AM
  #6227
Dallas J's Avatar
Veteran: Army
What Sean said, once timing offsets are involved the timing mark on the cogs are wrong. You care where the center is pointed. Think about what moves relative to the cam and that should be pointed to the valve cover mark.
Old Jun 28, 2024 | 09:12 AM
  #6228
Evo9isLife's Avatar
5 Year Member
cool. i think i only "need" a new IX valve cover. not sure if there JDM/EDM/USDM diffs.
1035A631 in amayama is 377 shipped. ebay 380 from japan + tax i guess. yahoo.jp 307 (not sure about shipping cost to my wife in jp. will find out)
JDM 9 valve cover does have a different pcv set up on the back with a different sized hole in the cover so you would need the jdm pcv too, unless you modify it to run an lines. STM sells the JDM cover too but they want $600 LOL. I love STM but I find myself going elsewhere more and more lately for oem parts because of their pricing.
Old Jun 28, 2024 | 09:40 AM
  #6229
ViciousLSD's Avatar
Originally Posted by LetsGetThisDone
The easiest way to do it is put the belt on. Then you now disregard the timing mark on the clogged part of the gear, and instead line up the timing mark on the center portion with the mark on the valve cover.
ok yup. just wondering if 1/2 tooth is the goal for initial setting. i wanted to put loctite on the bolts. will get back to this later tonight. thanks
Old Jun 28, 2024 | 09:42 AM
  #6230
ViciousLSD's Avatar
thanks. yeah i will drill it also for the AN fittings
Old Jun 28, 2024 | 09:53 AM
  #6231
griceiv's Avatar
short answer is no, that is wrong. you have 8° of advance dialed in there and the cam gear is in the wrong spot where you won't be able to get the belt on.
Old Jun 28, 2024 | 11:29 AM
  #6232
ViciousLSD's Avatar
ok. i dont think it would line up with the marks using the gear stopper anymore so the cam gears looks advanced? I will have to turn them with the belt and see
Old Jun 28, 2024 | 03:44 PM
  #6233
Where the mark is on the outer gear doesn't (really) matter. As long as there's enough adjustment for the middle part to line up with the timing mark on the valve cover. You can get the outer gear "close" for your sanity, but it really doesn't matter.
Old Jun 28, 2024 | 09:56 PM
  #6234
ViciousLSD's Avatar
ok i think i got it. hard to trust the timing marks . so "+4 degree crank" = +2 degree cam
Old Jun 29, 2024 | 02:45 PM
  #6235
Looks close enough. Hard to tell since the photos aren't straight on angle.
Old Jun 29, 2024 | 05:27 PM
  #6236
V.8MR's Avatar
Now with tinted windows. Will prob try and order a seibon wingless trunk lid or an equivalent so I have a more stealthy trunk. Swap in oe arms with poly bushes and perhaps 2k less springs so I can drive this car. Else it's a track weapon that never sees the track and therefore is never used.
Old Jun 30, 2024 | 05:09 PM
  #6237
RallySport9's Avatar
Where are you going for parts exactly? I've checked Amayama and the list price is way cheaper, then when you check out and calculate shipping it's so expensive it makes up for the difference. You can't find new oem parts for much less than stm. The only thing overpriced is their small stuff. Screws, clips ect..
600 is honestly cheap for a new mg valve cover and youl be lucky to even find one new at all when it's discontinued. You need to pay to play especially when a car is 20 years old.
Old Jul 1, 2024 | 07:18 AM
  #6238
Evo9isLife's Avatar
5 Year Member
I hear you man, thinking about the discontinued oem parts I might need in the future gives me anxiety lol. Sometimes I do end up ordering from STM or MAP because there isn't any cheaper options or is a hard to find piece, but just a couple weeks ago I called my local Mitsu dealer and ordered a new 9 front bumper and the mesh pieces for about $100 cheaper than what STM is asking, and if you count shipping from STM its closer to $400 saved. The parts that are not discontinued yet are typically cheaper directly from the source.
Old Jul 1, 2024 | 12:44 PM
  #6239
kyoo's Avatar
any stock or stock frame turbo guys running the artec exhaust manifold on here?
https://artecperformance.com/product...41877671903404
Old Jul 1, 2024 | 12:56 PM
  #6240
kyoo's Avatar
Turbo arrived. Anyone know what this grinding is about? And if the wear on that one fin is ok? Oddly enough they said the Z is an error, and that this turbo should read 71HTA (not 71HTZ)
Confirmed all normal with FP, curious about the 71HTZ read, but whatever.
