Old Mar 4, 2022 | 08:41 PM
  #4546
Dallas J's Avatar
Veteran: Army
Originally Posted by alpinaturbo
Dallas
Is ER running your suspension all around?
When you say moderately stiff, do you mean 12kg front 14kg rear, or substantially more spring rate?
Yes, the V1 setup off my car is now on that car. And I think that's in the range +/- 2k at each end.
Old Mar 5, 2022 | 09:35 AM
  #4547
kyoo's Avatar
Originally Posted by Construct
Spot on. Extra droop travel (with helper springs) isn't all that helpful for motorsports situations.
It could help very marginally for daily driving. If you're going over uneven surfaces like a driveway entrance and you find yourself lifting a tire, some extra droop travel could reduce the thunk when that tire hits the ground again. But that's about it.
Unless you're jumping the car, in which case you're going to need a lot more droop travel.
there are other things that happen on track that don't happen in autox. in relation to suspension, riding curbings is probably one of the biggest, depending on the track. some tracks impossible, other tracks are a must and can be a bumpy ride/large differential, you won't necessarily want a super stiff sway bar when doing that but u may want a little bit of give in the suspension.
(not saying the above case means more droop is needed, obviously the inner tire would not provide any grip, just highlighting a case of difference)
Old Mar 5, 2022 | 12:09 PM
  #4548
ViciousLSD's Avatar
Not only that - a lot of things happening at the same time. rear wheel lift is mostly from the diagonal seesaw effect. this one is a standard 3rd gear corner and the outside front is gripping and (tire & suspension) compressing so its unloading the inner rear wheel. obviously that lift will be higher if going over a crest. top heavy car wants to topple over (CCW) so the body could be extending the shock also. its not all vertical forces, especially with stock aero
this is from that 4x4 wood under 1 rear tire. 145lb helper spring is uncompressed already.
also note that swaybars are like springs BUT it still has to go from unsprung to max-spring state, so to speak. has linkages and bushings to delay the maximum affect as well
Old Mar 6, 2022 | 10:26 AM
  #4549
Bee-Raddd's Avatar
Originally Posted by Dallas J
-4.0 front, -3.25 rear.
I run -5 front and -3.25 rear on slicks with aero on asphalt and im within the same ballpark of the ER spring rates so seems to be a going consensus among the 3 of us there..
Also, My head hurts with this droop travel keeper spring drivel going on in here for the last week now lol.
Old Mar 7, 2022 | 07:34 AM
  #4550
Balrok's Avatar
Ditto LoL.
Old Mar 7, 2022 | 08:14 AM
  #4551
ViciousLSD's Avatar
That's been going on for years lol
https://www.evolutionm.net/forums/mo...ispreloading=1
Old Mar 7, 2022 | 08:46 AM
  #4552
Dallas J's Avatar
Veteran: Army
Droop is a never ending debate. My car would not work with droop (rear diff and suspension setup designed to turn on 3 wheels).
My buddies MR2 needs more droop so the rear torsen has something to leverage off of. Its situationally dependent, but I feel its more related to the diff needs.
Old Mar 7, 2022 | 08:57 AM
  #4553
cmspaz's Avatar
-4, -3, 200tw on tarmac, so make it 4 of us.
Same with me on the droop stuff. Whether you have enough travel to push that tire to the ground with a helper or not, you're not getting any real tractive benefit from it when there's no load on it. Just focus on maximizing the work the outer tire can do and call it good.
Old Mar 7, 2022 | 09:01 AM
  #4554
ViciousLSD's Avatar
in Autox, my rear tire has a violent landing. I think if the lift is too high my rear LSD is engaged before it lands. That hasnt happened since I got stiffer front springs.
For track I doubt those kinds situations would occur since you're going fast enough for that tire landing
Old Mar 7, 2022 | 09:47 AM
  #4555
Dallas J's Avatar
Veteran: Army
Once the tire lifts the bar has dramatically less effect on roll rate. So I tell people to use the rear bar to tune when and how long the tire lifts. If yours is causing issues being too high, less bar wont effect mid corner but will change how much its lifted and how early it sets down.
Old Mar 7, 2022 | 09:56 AM
  #4556
ViciousLSD's Avatar
I agree with you, but i think another major factor is driving style/skill. no left-foot-braking skill here, so I'm dive bombing in these extreme(autox) cases
Old Mar 7, 2022 | 04:54 PM
  #4557
Bee-Raddd's Avatar
Before you start babbling on about droop again...
Installed paddle shift into the evo and got it working. The gearbox is now shifting in 6ms according to the gear position sensor. total shift time including ramped recovery etc is about 50ms now. Heres the fastest lap from this weekends racing. car was on rails. this lap was a little bit scrappy especially the last turn i screwed up the entry but it was still fast none the less.
Paddleshift was surprisingly basic to set up and not too expensive when u dont buy a complete kit with 100000% mark up on it.
Old Mar 7, 2022 | 05:34 PM
  #4558
kaj's Avatar
kaj
That's awesome for sure! I have almost enough saved for my sequential, in case I keep the Evo. I'm not racing, so can be okay with slower shifting and just enjoy it. This video gets me all psyched again.
Old Mar 7, 2022 | 08:48 PM
  #4559
ViciousLSD's Avatar
You sure you're not lifting a tire into segment 3 ? :P
Old Mar 8, 2022 | 04:21 AM
  #4560
Meathooker's Avatar
https://www.youtube.com/watch?v=To2RZuYJZhU
what trans do you have? What type of paddle shifters?
