Old Mar 18, 2022 | 02:55 PM
  #4591
kyoo's Avatar
you might need this to check if strut bar is level, then check camber
https://www.harborfreight.com/digita...uge-63615.html
I have a bar that I use so I can lean this on the tire/wheel
you can also use it to check if your gauge is level
well i figured it didn't matter where it was. I set it to 0 sitting on the rotor and adjusted the angle til it read that the camber was positive half a degree.
apparently i need to change toe again, thought with toe being independent i'd be good. if it's not i need to get the rears aligned.
Old Mar 18, 2022 | 03:03 PM
  #4592
ViciousLSD's Avatar
my rotors are not flat enough, so I would use the hub face area or the edges if i was test fitting stuff.
just get a couple of rulers from HF for toe. you'll need it since youre doing more DIY
Old Mar 18, 2022 | 03:05 PM
  #4593
Dallas J's Avatar
Veteran: Army
I do the same thing. Once I know what the camber is, I adjust by a delta to get where I want. It works pretty great.
When Im setting alignment, I use some milk jugs half filled with water and a filled tube between them. Then I can level the spots on the floor with 1/8" tiles till the water is even in both jugs. I only do left/right. Dont care about front/rear.
Old Mar 18, 2022 | 03:09 PM
  #4594
kyoo's Avatar
what do u do for toe when u change the camber?
Old Mar 18, 2022 | 03:13 PM
  #4595
kyoo's Avatar
FWIW, the Evo came in at 3,116lbs after all the weight savings and balance changes I made this off-season. That's with a quarter tank of gas though. Figure with a full tank, about 63 more pounds, about 3,180lbs. pretty happy with that result overall (This is an MR with the 6 speed still), about 80lbs lighter than 2 years ago. and back to 60/40 (from like 63/37)
Old Mar 18, 2022 | 03:27 PM
  #4596
ViciousLSD's Avatar
https://www.harborfreight.com/72-in-...vel-69114.html
Old Mar 20, 2022 | 02:26 PM
  #4597
kyoo's Avatar
ok so car definitely has creaking when there's any amount of left turn in the wheel. car was looked over and aligned, any thoughts?
edit:: it's either direction, creaking quite a bit
Old Mar 20, 2022 | 02:33 PM
  #4598
RazorLab's Avatar
This is how I set camber. Super easy. I use a level that is long enough to go across the wheel/tire and use a digital level gauge in the middle. This is the much cheaper way to do it with the car on the ground so it's accurate.
I bought the digital level gauge for $30 and the level for $15.
Old Mar 20, 2022 | 06:06 PM
  #4599
kyoo's Avatar
steering:
Old Mar 20, 2022 | 08:02 PM
  #4600
Dallas J's Avatar
Veteran: Army
Weird, does it do it sitting without moving or only when driving?
Old Mar 20, 2022 | 08:12 PM
  #4601
Bee-Raddd's Avatar
check that the wheel and steering shaft arent rubbing on anything. check that the bolts on the power steering body are still tight ive had them come loose before.
Old Mar 20, 2022 | 08:50 PM
  #4602
kyoo's Avatar
haven't tried it sitting still.
nothing else changed but that stuff. I'll check clearances next time i get a chance under the car. not sure what it could be
gonna also check the springs. if it doesn't do it in the air it's probably that and I'll update the posts. that's what I'm hoping anyway
Old Mar 21, 2022 | 06:58 AM
  #4603
Terror Rising's Avatar
One of my AST front struts makes that exact sound. There's a section on the shaft that's slightly scored and if it rotates to a specific spot relative to the body it will do it. I end up jacking up that corner and rotating the shaft 180° via the top nut to make it silent again.
Old Mar 21, 2022 | 07:55 AM
  #4604
kyoo's Avatar
yea same suspsneion i've been on but yea i'm hoping it's just some spring bind or something
Old Mar 21, 2022 | 08:59 AM
  #4605
ViciousLSD's Avatar
This is how I set camber these days. I put nuts or sockets here and then settle the suspension, then measure camber on the tire/wheel.
I may need to find camber bolts or do the same spacer technique on the bottom, which is currently max'd out
