285/30/18 on 11" wheel
18x10.5 +38 with 265s was surprisingly easy to fit.
The same wheels with big 275s was a challenge. The extra height makes a huge difference.
Getting the front/rear positioning correct was key for me. PSRS, camber/caster plates, and Dallas' control arms combined for enough adjustment. Getting the fender liners tied back and molded out of the way helped.
Now that I've got it figured out, I'm tempted to try 18x11 with wider tires. This setup wouldn't pay off for NASA classing, though. The wider 275 tires on 10.5" wheels already won't clear the tire template tool and I don't think stepping up to 285s or 295s would be worth the penalty.
I removed the springs and fully tucked my 18x10 setup when I was doing fitment. It took some fine tuning but it doesn't rub anywhere under compression.
If I went with another 0.5" of wheel I'd have to take most of it from the inside clearance, though. That becomes harder to judge at static compression because tires flex inward under cornering.
For the rears, i think there is still atleast 10mm to the frame, just need higher offset wheels and/or lower profile tires. I may try revisit the camber bolts much later. If I do tuck that in then the front would be tracking wider
That card isn't playing out like we'd think it seems. Last weekend folks switching to the RR's are 1-2 seconds behind those on A's still with 50hp increases in TT. Well known guys with solid teams and cars. Goes back to that old saying, if you can't put the power down. But I think that's mostly due to time and setup. There's just far to many options now for anyone to say "here's a baseline" like we have for the purple crack. And these 200tw's don't last "on the shelf" nearly as long as hoho's before they switch them out for the next model. The 100tw's and below like NT01's and such have had that time but it'll be interesting to see the long game results. I think they're still short on power to make up the real difference. Plus lots of these cars don't have "all" the aero to maximize grip to a specific tire like you're seeing in WTAC.
A Toyo RR vs a Yoko A052? Yea that's not surprising in the slightest, the A052 isn't using a compound that's decades old lol.
I'm talking purely about widths here. Compound will always play a much larger role than width. I would still be looking for more power over more tire assuming you're on one of the competitive compounds. I can't imagine many of those other cars are AWD.
The upper arm is not adjustable. An adjustable arm is the only way you'll be able to change the rear track. I've talked about this with Dallas before but we concluded the market for such an arm just isn't there.
I was keeping this around in case I feel like retrofitting it :P
https://www.suspension.com/superpro/spf2601k
RRs have never been a competitive compound from what I've seen. I would fully expect a car on A7s to manhandle a car on RRs if they're within 100hp of each other.
