2022 STU discussion
The individual I have quoted works for TireRack. I also had a guy that works at a dealership call his suppliers and can't get exact dates. I'd assume something will happen in the next days/weeks if what he said is true. I'm definitely ordering a set if they offer it in the 285 variety initially...
Honestly, that's the million dollar question and I'm unsure anyone can say at this point. Bridgestone came out and said it was about 6 tenths quicker around tsukuba circuit than the outgoing RE71R.
I'm HOPING these tires heat cycle better than the old RE71R, which at half life, normally was falling off in grip. I'm just glad there's another 285mm tire offering that hopefully can compete with the A052.
I believe Grassroots said they'll have testing in the near future.
A052 is a bit of a magical tire that will be hard to fully beat. The new RE might stand a chance in some aspects, but A052 has a magical combination of cold, wet, and concrete performance. Of course heat and life is its struggle but for competition it will be hard to beat.
My TR rep called back on 265's. 1st 25 due in Indiana June 1, 19 left on pre-orders.
So we won't see these till mid June earliest I think. My wholesale price is in the upper 200's so retail will likely be in the 300-360 range.
From: Why do they always call the Evo the Dark Side?
Also some side notes I noticed/heard.
Sounds like last year's STU nats winner has moved on to another class/chasiss. The STI is still being used for STU by the new owner(s).
Looks like the Fiata took care of STU in DC this past weekend. Results here: https://cdn.connectsites.net/user_fi...pdf?1649623865
If you took Evan's fast time on day 1 + the fast time from the other Jacob on day 2, that chassis would have also took STR. Full disclosure, unsure the skill level of those names of the STR drivers from that event. And I get this is theoretical, but it does show the capacity of what this car is about. I still feel this car is incorrectly classed in STU. If you agree and haven't yet written in to express your opinion, here's where you need to do that. https://www.soloeventsboard.com/
EDIT: I still think the Type R in STU form could absolutely dominate as well....the thought has been crossing my mind more than once....
I don't know much about STR - Marcus did have a top PAX in DC last year in July and is usually up there PAX wise. It was in the 40's for temperature, so probably pretty good Yoko weather (but everyone was on Yokos). Pat Salerno is an Evo instructor, I think he has jackets, etc but I don't know the state of prep for his car. Same for Tim Aro, I think he has a CSP jacket.
I wonder what a full prep CTR would weigh in STU? What tires can they fit up front? I also wonder how long it is til we see a full prep FoRS. A little heavier than the Evo/STi but comes with more power stock and possibly a better stock set of differentials.
I'm dropping off my car next week for shorter springs/alignment but still not planning on running 285s this year while I get the car dialed in and try to have a "getting back into the swing of things" kind of year.
One other interesting datapoint was STX's winning time was (121.6) about the same as STU's winning time (121.6) - http://sololive.scca.com/NT/STX.php - Lenworth is the driver who had top PAX at the first DC event this year (mid 30s for temperature, I outrawed him but not by enough). You are right though, the theoretical best time in STU would have been faster if you combine the two days.
Thanks for the insight! I know, it's bench racing, but it is interesting to view data points throughout the year. Man, if it was that cold out, you'd think the evo would have an advantage vs it's STU counterparts on days like that!
I can't recall exactly who I was talking to, but the CTR weighs around 3050 stock - which is definitely lighter to begin with than the Evo 8/9 and obviously 10. I'd assume they would get into the 27XX-28XX range with full prep? I think I'm in the high 29XX range currently, but haven't weighed it since the last round of minor mods.
I swear I also read a thread about a STU type build for the Type R that was pushing upwards of 400whp. I believe I mentioned this before, but I supposedly there was one on the NE coast that ran a 315mm all the way around on 11" wheels in STU/SP trim. Uncertain if that is a myth or if it's the truth. Maybe it was the same car that was competing at that event? Although I found on RRX the car that was competing at this event was actually running a 295/255 combo,
More power, more tire, less weight than the evo. I wonder how "well" that FWD would put down 400ish whp though...?
https://www.civicx.com/forum/threads...ptp-usr.30111/
https://nationalspeedinc.com/2019-ho...pe-r-bolt-ons/
Kinda looks like ~375 whp is possible with stock fuel / 93 octane / ST legal mods. I mean, every dyno is different and all that. But that does sound like pretty solid power to weight. My car was 3085 with 17x9s and 245s so I'm probably slightly over 3100 on the current wheel / tire setup (plus I have a normal battery now) - that's a 6 speed but even with a 5 speed swap and all available mods that I haven't done, maybe 3025 lbs.
A 315 Yoko and a good diff would put down power pretty well I would guess. It looks like the FK8 CTR is four inches wider than an Evo though:
https://www.edmunds.com/honda/civic/2021/type-r/
Overall Width without Mirrors: 73.9 in.
https://www.edmunds.com/mitsubishi/l...eatures-specs/
Overall Width Without Mirrors 69.7 in.
https://www.civicx.com/forum/threads...-400whp.24588/
The CTR just looks like a fun car to own overall.
Good information and thanks for sharing! I didn't realize that car was 4 inches wider than our beloved evos.
Spring Nationals in Lincoln is open for registration. So far in STU we only have 6 signed up. I'll probably have a co-driver so 7. Hoping to see a few more faces out there from CO and other regions. Time will tell. I know we've lost a couple of bigger names in STU - hopefully this class holds strong again for '22.
https://www.motorsportreg.com/index....84B593DC73F3B3https://www.motorsportreg.com/index....84B593DC73F3B3
RE71RS tires are showing up on TireRack's website, however, the majority (if not all) are showing as 6/1/22 expected dates.....Sounds like they will be updating the dates on their site soon.
https://www.tirerack.com/tires/tires...71RS&tab=Sizes
