North Texas Evo Club (NTEC) For discussions in and around North Texas
service engine soon light need help
Old Aug 29, 2009 | 04:03 PM
evoevo8's Avatar
wat up guy the service engine soon light come on on the odometer any one know how to turn it off ?? also is that light mean i needed regular maintenance or there is something wrong with my engine? any help will be great thank.
Old Aug 29, 2009 | 04:20 PM
Evo-Mike-2's Avatar
How many miles on the car? Is it acting up?To turn if off just take the light out.lol
Old Aug 29, 2009 | 04:32 PM
evoevo8's Avatar
57k mile, car run fine not acting up at all
Old Aug 29, 2009 | 05:04 PM
Evo-Mike-2's Avatar
Have you changed the tranny fluid ? And what is done to it and have you anything done to it lately?
Old Aug 29, 2009 | 05:58 PM
mt057's Avatar
Go to autozone and get the code pulled. If it something non-important it can easily be tuned out. I have turned off my p0300, EGR, and rear o2 sensor with out using a resistor with no cel now. If it is something serious you will want to know.( It sounds like nothing though)
Old Aug 29, 2009 | 06:22 PM
denver's Avatar
Probably P0300.... most of the time the check engine light on an 8/9 is nothing to worry about if the car is running fine.
You can pull the code at autozone and post the code, or go come evodynamics if you are in DFW, and we can shut it off, and check to see that nothing is serious is going on.
P0300 is a standard code for evos it is "Random Misfire" which means the something didnt go exactly perfect on a spark so it throws a code... nothing to worry about at all. We can turn it and most of the other pointless codes off so you dont get them anymore.
Old Aug 29, 2009 | 09:39 PM
evoevo8's Avatar
i am goin to autozone tommorow and get the code and will post it up. thank everyone for the info. just bought the car and drove it for 10k mile now and sure of it history so i do need a tranny fluid and tranfer case fluid change. as for the car it was tune by kevin d a couple month ago and car run great and i am goin to get a retune cause i just got the cam, intake, and bov (not yet install).
Old Aug 29, 2009 | 09:42 PM
evoevo8's Avatar
and hey denver it was kool to meet you and kevin, i will contact you guy for a retune and intallation of the new part i just got
Old Aug 29, 2009 | 11:19 PM
lauren_EVO8's Avatar
My check engine light was on for a long time on my evo 8 but it ran fine, and they cleared the code many times but it came back on eventually, i got new spark plugs and a new coil pack and it went away
Old Aug 30, 2009 | 12:51 PM
evoevo8's Avatar
ok just got back from autozone and it throw a po401 code which is a EGR problem, i still have my stock 8 dv and i am running about almost 23psi, i just bought a forge dv but not intall yet would it solve the problem if i have it install?
Old Aug 30, 2009 | 12:54 PM
evoevo8's Avatar
hey mto57 wat u do to get rid of that EGR code ? a retune or a better dv i still have my stock 8 dv
Old Aug 30, 2009 | 02:29 PM
mt057's Avatar
Having KevinD turn it off would be the easiest option unless you are familiar with your ecu. Look into the mapping periphery bits in the ecuflash section.
Old Aug 30, 2009 | 02:51 PM
KevinD's Avatar
disabling the EGR isn't a good thing for a daily driven car. you will get worse gas mileage. the one benefit of eliminating it is that it keeps the intake manifold cleaner from the exhaust gases not coming in. its very easy to fix that code, and even if you don't do anything about it, its not going to hurt anything.
Old Aug 30, 2009 | 08:00 PM
evoevo8's Avatar
hey thank ever one you guy been a real help
cts4g63
Mar 17, 2017 08:08 PM
impact blue
Feb 6, 2013 06:32 AM
davidmitsusrock
Lancer Engine Tech
15
Nov 20, 2007 04:18 PM
eponti
18
Sep 30, 2006 02:55 PM
djmikeymike
Mar 15, 2005 01:42 PM
