Philadelphia's Classiest Drunkards
Old Mar 8, 2012 | 06:10 AM
  #33721
dek0026's Avatar
Subtle "I'm gay" post
Old Mar 8, 2012 | 06:11 AM
  #33722
dek0026's Avatar
In other news: Ryan hates us
Old Mar 8, 2012 | 06:12 AM
  #33723
psushoe's Avatar
I like to use the eye ball method. I park next to a wall and estimate how far my tires are leaning in for camber. Then I walk around the front of the car, crouch down and look at both front tires at the same time to estimate toe. Where you crouch is very important, as being too close will not let you see both tires at the same time. Also, you have to be on the center line of the car. I usually find about 1/4mi from the tip of the front bumper as the best distance. Repeat for rear toe, only you obviously stand behind the car. Don't forget to turn around and face your car, otherwise you might be measuring toe on your neighbor's car instead of your own.
Old Mar 8, 2012 | 06:19 AM
  #33724
dek0026's Avatar
Quoted to prevent deletion or editing.
Old Mar 8, 2012 | 06:21 AM
  #33725
AlwaysinBoost's Avatar
I'm bringing my bad *** alignment rack to LVGP Monday. Ya'll gone see wats up!
Old Mar 8, 2012 | 06:23 AM
  #33726
honda-guy's Avatar
How do you eyeball for caster. Do you turn the steering wheel and look at the hellaflush angle.
Old Mar 8, 2012 | 06:25 AM
  #33727
grillpt's Avatar
Hey AIB, looking at the GVC WGI event, registration is not open yet or what? I know they're caping the field to 60 drivers, just want to figure out what I need to do to register... They also state you need to be a BMW CCA member, that aight gonna happen.. Just curious on your thoughts about all that?
Old Mar 8, 2012 | 06:26 AM
  #33728
psushoe's Avatar
Caster is tricky. I'd tell you my method, but it took a long time to develop and I'm keeping it a trade secret. I will say the hellaflush angle is a step in the right direction.
Old Mar 8, 2012 | 06:37 AM
  #33729
Membership has its privileges.
I don't know what the deal is. I did it backward and signed up for the Sept. WGI event w/GVC first instead of the May event. My reg is still pending for the May event. Once they realize I am in their system as an approved instructor I should be good to go for both.
Old Mar 8, 2012 | 06:52 AM
  #33730
steinvb12's Avatar
Originally Posted by Jeffroevoix
Stupid tech question, but does my car need to be inspected??
No, but you might need a valid license.
Originally Posted by dek0026
i'll be going up 401 to 23.
is it a left onto 23 then right onto 10 and it will be on the left hand side?
i'm still not definite about my participation but knowing where to go is half the battle.
Once you get on 10, make sure you go through the figure 8, sweep back around to 23, ricer flyby the Sonic, hardpark. You'll know it when you're there.
Old Mar 8, 2012 | 07:04 AM
  #33731
I just checked the reg list for both GVC WGI events and its pretty full. 248 people reg'd over three days. I think they are counting some people more than once, though.
3 days @ WGI = Nguyen!
Old Mar 8, 2012 | 07:36 AM
  #33732
grillpt's Avatar
^ You doing all 3 days in May?
Old Mar 8, 2012 | 07:37 AM
  #33733
I am reg'd for all three but have a project due at work on the 4th, so I may only be able to do two. Its a haul up to WGI so I have my fingers crossed I'll be able to get three days in.
You signing up?
Old Mar 8, 2012 | 08:15 AM
  #33734
honda-guy's Avatar
Im going to try to get in for GVC glen in may also. Pete, sign up son.
Old Mar 8, 2012 | 08:35 AM
  #33735
Tims2006MR's Avatar
If anyone else is cheap
http://www.gearheaddeals.com/2012/03...-oil-for-free/
