Philadelphia's Classiest Drunkards
Old May 11, 2010 | 02:08 PM
  #5086
colonelfox's Avatar
Originally Posted by BBS
Except that small scar on her shoulder stinks like rancid butt juice and makes you queezy even thinking about it
Dude I would lick the scar if it got me more power.
Sir, Dan has an ETS exhaust and I think its one of the best sounding systems Ive ever heard. Very throaty and growls.
Old May 11, 2010 | 02:19 PM
  #5087
dek0026's Avatar
Originally Posted by CatalystGod
Don't hold your breath. My wife says I always screw up something or the other when I work on my car and that I shouldn't. She's probably right. I might want to install everything this weekend, but I'll be really pushing my luck if I do everything right. God help me!!!
Parts going in this weekend:
1) Mishimoto Radiator & Hoses
2) ETS Intercooler Kit
3) ETS Intake
4) ETS V2 Exhaust with 300 cell HFC (Quad tip, hope it turned out nice, boxes still unopened in VA)
Following will be put on when I go to get tuned
5) Synapse BOV with entire connetivity kit(Group Buy taking forever to ship)
6) GrimmSpeed 3 port solenoid.
I am hoping for low 300s on pump gas.
I'm pretty sure I won't be setting any records, and Dan, you can forget about the race, Just the fact that you're running E85 is enough to blow me away. So what are you really pushing to the wheels, were you serious earlier? If so, holy cow!!!
BTW, at first sight, I read your previous statement as " get your pants on and tuned."
my iphone causes all kinds of typos. i meant parts.
you'll probably make 330 to 345 after the tune. the 3 port solenoid would be my next mod along with cams. the only thing going against you is the amount of boost and timing you can run with pump gas. that set up on e85 i'd bet would get you at least to 370 on that dyno or more. on e85 and the stock turbo the boost is totally maxed out as far as i know.
if pete's tuning it, he'll tell you all about what he can and can't do.
Old May 11, 2010 | 02:24 PM
  #5088
dek0026's Avatar
what's the max boost you think I can push safely? just asking out of curiosity/lack of knowledge. I am thinking 25 to 27 psi, are those high expectations for pump 93?
I really want to max out the stock turbo and enjoy it to its full capacity for an year. I will look to upgrade the TC/manifold/DP and suspension stuff next year.
i doubt you'll max it out on pump gas. there are people holding 30 psi on e85 on the stock turbo using the 3 port and wastegate mods.
i am not a tuner but you'll probably be anywhere between 24-26 psi i bet......that's because i'm a betting man i live dangerously.
Old May 11, 2010 | 02:57 PM
  #5089
CatalystGod's Avatar
You did write "PARTS", I read it as "PANTS", gotta get my eyes checked.
Was that directed to me? I agree, I really love the ETS growl, but I got it with the resonator and HFC to ensure it wasn't too loud for the VA Roads. By now all of you must've figured out how much VA sucks for performance junkies. The only thing I did not get is the DP. I'll be doing that with the turbo swap next year or maybe even sooner if finances permit. This is what I do every year:
Months 1- 3 : Save all money earned for long term savings.
Month 4 - 6 : Spend it crazy on stuff I want.
Month 7 - 9 : Save again
Month 10 - 12 : Spend again.
I'm a contractor and don't have a 401K etc, so I just save up whatever I can for the rainy day. Its worked fine so far for me. I have both the cars paid off too so its all cool.
Haven't spoken to Pete directly yet, I did not want to waste his time before the car was ready for a tune. I figured I'll just do everything and then drop him a line.
Old May 11, 2010 | 02:58 PM
  #5090
chu's Avatar
chu
I can say 24-26 with confidence. I don't think any tuner will boost than that on 93 and tell you to your face it's a safe tune. However, I will leave it to the expert tuners to tell you whats best.
  #5091
BBS's Avatar
BBS
Any audiophiles here? I need a double din navi unit for my nice new orbital kit waiting to be installed.
eyeing the pioneer x920bt or the alpine w900
Old May 11, 2010 | 03:07 PM
  #5092
Did you consider this?
http://store.mp3car.com/
Its not for you if you just want it do whatever you want. you'll need to tinker a little bit with it.
Old May 11, 2010 | 03:11 PM
  #5093
dek0026's Avatar
pete tiebout is the guy to talk to about audio stuff.
Old May 11, 2010 | 03:53 PM
  #5094
boostedtres's Avatar
since apparently certain "people" thought I died, just figured i would drop in and say hi. hope everyone is doing good. battling allergies, teachers, finals etc. later guys (and no new injuries to report mr. chu) haha
Old May 11, 2010 | 04:25 PM
  #5095
Dd any of you look at this thread?
https://www.evolutionm.net/forums/se...t-service.html
He's doing 38 psi on a stock 9 turbo. I knew the 9 had a bigger turbo than the 8, but damn that's high. Can the turbo on the X even hope to put out that kind of PSI?
Also, People keep saying that the pump gas limits boost to around 26 PSI, is that due to the octane and burn characteristics of the gas or the turbo? Is the limitation the same no matter which turbo we use? I thought if you made more boost and pump more fuel using the injectors, the ratio is still kept safe. The only downside would be the timing. It'll probably need a little bit more advance to ensure all of the mixture burns and in the process, cause some knock.
Old May 11, 2010 | 04:33 PM
  #5096
grillpt's Avatar
Come on... you haven't hurt yourself at all? No good roofs to skydive off of?
Old May 11, 2010 | 04:55 PM
  #5097
colonelfox's Avatar
Any turbo can run that high. It's how long it will run that way and how hot the charge air is as it leaves the compressor housing that really matters. There isn't a magic boost number that translates to power, it's all in the efficiency of the turbo. You can make more power at 20 PSI on a more efficient turbo than 40 PSI on a little one. The IX turbo is great but I can almost guarantee he won't make it more than 5-10K miles before it grenades. As boost increases so does the RPM the turbo is spinning, and the faster it spins the quicker the bearing surfaces wear due to lack of adequate lubrication and the various loads the shaft sees at upwards of 100000+ RPM. Simply put the oiling system can't keep up and the turbo was never designed to spin that quickly. A smaller mass wheel has to spin at a higher rate to reach that output. Advances in blade design have helped but there's only so much you can do before it becomes a rotational issue as opposed to blade design. It's compressor wheel and housing at a certain point stop being efficient and start blowing hot air. When the charge air is hot as it enters the engine it's causing pre-detonation and not making power Ie: knock. The pump gas limit is more detonation and engine based. Engine limitations aside, higher boost leads to higher cylinder pressure and if it gets too high, certain fuels can't properly combust without help of some sort and you also get pre-detonation then as well. Hope that makes sense I have a tendency to ramble on.
Old May 11, 2010 | 05:35 PM
  #5098
bsander's Avatar
well said josh
Old May 11, 2010 | 05:37 PM
  #5099
dek0026's Avatar
what josh said.
and what pete said earlier. it just starts blowing hot air.
the replies definitely reflect the personalities.
Old May 11, 2010 | 05:39 PM
  #5100
dek0026's Avatar
i may show how little i know but physical properties aside doesn't the boost controler (whatever may be controling) start creating an obstacle as you increase boost to super high levels?
idk. i am going to stop posting. i know what i want to ask but the brain shut off already.
