Philadelphia's Classiest Drunkards
Old Mar 9, 2010 | 11:39 AM
  #751
dunk186's Avatar
Originally Posted by AlwaysinBoost View Post
^i'm looking for a good condition long block to build... lemme know what you got son!
mark look on craigslist i saw one in allentown for 1200 bucks almost sounds to good to be true, but worth looking at !
Old Mar 9, 2010 | 11:43 AM
  #752
chu's Avatar
chu
Could prolly get it for less since it's in the area. I got one from a vendor (Evoparts-R-Us, on here for $1100 shipped, mint condition VIII block. He even gave me a copy of the title and the junk-yard receipt for the motor.
Old Mar 9, 2010 | 11:44 AM
  #753
turbotekray's Avatar
here is the worlds famous joe up video!!!!! and this is actually only part of it
http://www.youtube.com/watch?v=YcVVpzAVlFU
  #754
ek9evolve's Avatar
My understanding is that the helper springs help accommodate the overall loss of travel you see with a shortened spring. Under a full droop situation the spring would unseat itself depending on the ride height of the vehicle. The helper is there just to fill the void and not provide anything to the actual overall spring rate.
Old Mar 9, 2010 | 11:51 AM
  #755
grillpt's Avatar
Originally Posted by chu
Only 40 percent chance of percipitation, so I think it'll be okay! I hope we pick up some wind and move it out of the area though. No, I dont think Chau is coming. If you dont go, I have no reason to sleep over!
I didn't think you planned on staying over anymore... not unless you get really tossed.
Originally Posted by 06RS
Do you want to miss Hopslam or the Nugget Nectar Firkin? I don't know that they will last the whole night.
I've never had the Hopslam, but I'll take my chances...
ohhh, they have NN firking? I'm gonna have to compare that to the bottled stuff. Do they have the Yakima Cask? That was tasty!
They did have the Yakima, I've never tried that either. I doubt they will by this weekend, that was two weeks ago (I think).
Geez, you got a longblock laying around too, what don't you have Chu? You prob have a spare chassis around somewhere don't you...?
Old Mar 9, 2010 | 11:52 AM
  #756
chu's Avatar
chu
So I'm right?...since helpers collapse when the car is seated on all fours. So it really is for droop travel, and nothing more. Does this mean me springs will unseat itself in corners, or when I put it on a jack, once I lower my car? Given the fact that I do not have helpers on my coilovers?
Old Mar 9, 2010 | 11:53 AM
  #757
chu's Avatar
chu
No, no. It wasn't for me. It was for someone else, who aren't on the forums. I do have a set of GG fenders, fornt and rear bumper, VIII tails, and a few other things! lol. I saved Will with a IX lip I had when the snow claimed his! lol. I guess I just buy things when it seems like a deal...like the axle that sat in the basement for almost a year, and I ended up needing!
Old Mar 9, 2010 | 11:54 AM
  #758
Kevin.'s Avatar
Originally Posted by ray@revitup
here is the worlds famous joe up video!!!!! And this is actually only part of it
http://www.youtube.com/watch?v=ycvvpzavlfu
hahahahahaahahahahahaha
Old Mar 9, 2010 | 12:00 PM
  #759
i have some others i can share, my brother in law is priceless
Old Mar 9, 2010 | 12:04 PM
  #760
ek9evolve's Avatar
Yes, that is correct the helpers are more for precautionary purposes. However its not like every full droop scenario will unseat the spring. You are lowered remember, the overall distance from your top mount perches to the base of the spring has shortened.
I remember reading a lengthy post in here that was related to Vorshlag's parts development on a white X. They had A TON of listed information on their suspension set up, justifying why each change was made along the way. They started with basic coils and kept adding from there. They did talk in length about helper springs, I know they never ran them because the travel seen under driving conditions didn't warrant their necessity.
Really only thing to worry about is the length of your spring and can it compensate a fully slacked or drooped travel condition. The higher overall length in a less stiff spring needs the extra travel so it doesn't bottom out on itself under full loading. This then jacks your spring rate up to infinity, no bueno. A much stiffer spring doesn't need the extra travel length, so Marc is correct there. Get a shorter spring with higher rates, be able to sustain a lower ride height, and most likely not need a helper.
Very simple explanation really, there's quite a bit more that goes into a proper selection and coordination components in an individual setup.
Hope this helps.
Have two pics below, helpers are on but are on the top, but from the angle it doesn't show them at all. Either way the coils in the box have the helpers on them to show their puny status compared to the main spring.
Old Mar 9, 2010 | 12:22 PM
  #761
chu's Avatar
chu
I wonder if I would be able to add helpers to my setup, as it does not come with them from the factory. I dont like the idea of the spring unseating when one side of the car is at full extension. It wouldn't matter at full height, but I want to lower 1 inch, and that would give the spring that much play room when I'm lifting.
Old Mar 9, 2010 | 12:23 PM
  #762
dek0026's Avatar
What is the difference with NN Firkin? That will be my first. Hopslam I can do in small quantities.
Old Mar 9, 2010 | 12:24 PM
  #763
grillpt's Avatar
I'm trying all of them...
Then I'll puke...
Old Mar 9, 2010 | 12:26 PM
  #764
Monochrome's Avatar
Originally Posted by dek0026
Drafting room bar, little hawk. (tribal drums in background)
it is in exton. you should come.
I would seriously, but I'm going to the outer banks this weekend to work on a friends VR4 and enjoy the beach.
Old Mar 9, 2010 | 12:41 PM
  #765
SASD209's Avatar
Admin Alumni
Originally Posted by turbotekray
i hope brian can change it soon
Done/
When I put the request in for you, Brian said he didn't have that power, but he has forwarded it to the Admin...SASD! You should hear from them soon enough.
Fixed.
