Philadelphia's Classiest Drunkards
Old Jun 23, 2010 | 08:06 AM
  #7786
AlwaysinBoost's Avatar
Originally Posted by grillpt
Yes it does!
I'm on stock MR suspension, hardly a performance upgrade. I bought them for the smoother ride, I hated the KYB's. Your suspension alone cost as much as I've spent on mods for my car... probably more.
No, I was refering to Marc's car. Although, Chu's is also pretty well set-up minus the Hoosiers.
I don't agree that a couple expensive parts = prepped.
I could throw all the JDM, Takita, Volk and APC parts made on my car and it would probably add up to be more in part than what my car is worth. That doesn't mean its prepped at all. All it means is that you spent alot of money on a bunch of parts.
Prepped means you have gone over the rule book and 'prepared' your car based on it... like Corey & Cy did, or like Mike has done. their cars are what I would call 'prepped'... they have every allowable mod under the sun and their cars are setup to exploite those mods. That is the definition of Prepped. All I did was buy a couple of parts I could grow into. my car still has a LONG way to go in order to be put under that catagory.
Dan, you should do this if you can. There's no need for you to run in SM, you should be in BSP anyways. I'd like to run first, work second and leave. Its gonna be hot as b@lls this sunday.
If you can't make it I'll meet you if Marc wants to get his helmet back, thats no problem.
no rush on the helmet... I was just bustin his chops.
Old Jun 23, 2010 | 08:24 AM
  #7787
grillpt's Avatar
To me your car is prepped... I never said it was Bruce and Chuck done up, but certainly the most prepared car in our group, maybe even the most in SM this season. Do you disagree?
Jeez, not trying to argue with you... why couldn't you just have taken it as the complement that is was instead of arguing with me about it.
Old Jun 23, 2010 | 08:28 AM
  #7788
BBS's Avatar
BBS
The us soccer team needs to capitalize on these open shots. UNBELIEVABLE
Old Jun 23, 2010 | 08:29 AM
  #7789
BBS's Avatar
BBS
Old Jun 23, 2010 | 08:34 AM
  #7790
BBS's Avatar
BBS
Old Jun 23, 2010 | 08:42 AM
  #7791
STFU, I'm not arguing with anyone, just trying to get my point across.
I think Locket has the best prepped car... might not be the best choice of cars for the class, but as far as modding per the rule book goes I think he is the winner.
I dunno I would consider myself the best prepped outta the group either. Carson & Chu both have more mods then me AND they're cars are making more power(that last part I will be correcting in a couple weeks). All I have on them really is better tires.
Old Jun 23, 2010 | 08:50 AM
  #7792
grillpt's Avatar
Must be nice to be able to watch tv while at work...
That accounts for a lot right there.
Old Jun 23, 2010 | 08:53 AM
  #7793
dek0026's Avatar
just pre-reg for Novice BSP and pick a 2nd heat work assignment. you'll run first heat and work second heat. that will get you outta there early and we can work on driver development cause you won't be running in the same heat with all us SM guys.
i know this has been asked before and i didn't pick up on what the answer was but is there a way to pick my work assignment before the event?
i am not a member as of yet. this whole paper thing really is causing me to procrastinate. i tried the website but it sent me an error message after numerous attempts to join.
thanks. i could bring it out to you if i end up not being able to make it.
i know marc was kidding about it but i don't feel right keeping it as long as i have. i should have brought it to KHC that day but forgot.
  #7794
no doubt. tires are the most important part on the car.
Old Jun 23, 2010 | 08:56 AM
  #7795
chu's Avatar
chu
I was late into the game as far as modding and racing goes! If I could go back, I would stay stock ,and run stock all the time. But I have to make a compromise and drive my car as a dd and autox. It doesn't help that I'm changing stuff constantly! On the topic of prep, I think it is. On setup, it's not ideally competitive...still need better tire, and suspension setup.
Old Jun 23, 2010 | 08:57 AM
  #7796
you don't need to be a member to take advantage of that. All you have to do is pre-reg. When you reg list NOVICE as your PAX and BSP as your Class. When you get there on Sunday and 'check-in' at the pre-reg table, tell them you need a 2nd heat worker assignment cause you're running 1st heat.
Old Jun 23, 2010 | 09:05 AM
  #7797
btw, I'm all pre-reg'd for Sunday. Its pretty bad when you know your CC#, exp date & security code by heart
  #7798
BBS's Avatar
BBS
no tv at work. espn3.com streams all the matches. WHAT a finish for the us. On the verge of not advancing to the next round to winning group c. WOOW
Old Jun 23, 2010 | 10:17 AM
  #7799
grillpt's Avatar
Its cool, I'll see you friday night at boscov's anyway right?
Old Jun 23, 2010 | 02:25 PM
  #7800
CatalystGod's Avatar
What do we have this Sunday? Another Auto X? Where at?
