Philadelphia's Classiest Drunkards
Old Mar 14, 2010 | 08:11 PM
  #1321
ek9evolve's Avatar
So is anyone's setup remaining in similar fashion to last year?!
That is of course besides me...
Old Mar 14, 2010 | 08:15 PM
  #1322
chu's Avatar
chu
Pete's setup isn't changing much, besides a wheel/tire upgrade!
Old Mar 14, 2010 | 08:42 PM
  #1323
Monochrome's Avatar
Well I took the EVO down to the Outer Banks this weekend and lost the ACD along the way (all 3 lights came on). Of course, I didn't have my manuals with me for this trip, but after an hour of searching I found how to pull the code (code 82 bad pump). Oddly, the pump still turns on when I turn on the ignition and push the gas pedal so it can't be bad. I bled the system really well (which wasn't even low on fluid) and it didn't change anything.
Turning off the ignition and back on will reset the system and it'll work for about 1/4 mile then disable itself again.
It was raining during most of the drive so I wonder if water getting on the pump/sensors is causing the issue. I'd hate to replace the pump if it's not bad.
Any ideas?
Old Mar 15, 2010 | 04:50 AM
  #1324
metal4all6's Avatar
Originally Posted by AlwaysinBoost
took advantage of the extra daylight and got a lot done on the evo to-do list today.
moved oil cooler forward so it no longer rubs @ full lock.
flushed driveline fluids. used redline MTL in the trans and HW shockproof in the TC & rear.
I took samples of the TC & trans. The TC fluid was still bright pink and there were no visable metal shavings on the drain plug.
changed oil to ams 0w-30 oil & oem filter
flushed coolant
installed new rotorpros rotors in rear w/new ds2500 pads
fresh ngk br7es gapped @ .028
finally put on the IX turbo w/ppi proted & coated 10.5 hotside
new gaskets for hot parts
installed JMF fmic
new bosch o2
still need to do before Sunday:
order front pads and install
flush brake/clutch fluid
boost leak test
put everything back together
Sounds like a productive day . I need to go put together a boost leak tester one of these days. I probably have a few leaks.
Old Mar 15, 2010 | 05:01 AM
  #1325
grillpt's Avatar
flushed coolant
installed JMF fmic
new bosch o2
boost leak test
Dam, you were busy... even knocked out the turbo swap, I'm impressed.
Originally Posted by chu
I've got a new interior in! ok ok, just new front and rear seats. Anyone who saw my car yesterday, the Buddy Club is out of the car. It was a nice comfortable seat, but I can see getting in and out of it everyday. I drive too much! Who's got a weekend only car?
The question is who can actually fit in that thing... Too snug for me. I think Shelly and Kittens are the only two... good luck.
What did you do to the interior now?
Its true, my set-up hasn't changed besides 17 x 9.5's and some 255's starspecs. I plan on having my harness in by the 28th as well.
Old Mar 15, 2010 | 05:02 AM
  #1326
AlwaysinBoost's Avatar
^ you can borrow mine if you want, or just come by the garage and we can test it for you.
Old Mar 15, 2010 | 05:03 AM
  #1327
grillpt's Avatar
Dan, thanks for the kind words about the house. Its been more work than I ever possible imagined it was going to be.
I was hammered when i got home the other night btw...
Old Mar 15, 2010 | 05:04 AM
  #1328
grillpt's Avatar
Sorry Marc, you lost me borrow what?
Old Mar 15, 2010 | 05:24 AM
  #1329
that was meant for Brian. no boost leak tester for you, I need to slow you down somehow.
Old Mar 15, 2010 | 05:30 AM
  #1330
metal4all6's Avatar
Awesome, thanks for the offer Marc! Are you free at all this week to test it?
Old Mar 15, 2010 | 05:47 AM
  #1331
metal4all6's Avatar
It's slow in here this morning. The baby decided to wake up at 4:30am and my wife is sick so I took a sick day from work.
Old Mar 15, 2010 | 05:53 AM
  #1332
grillpt's Avatar
Awe come on... I wanna go fast like Ricky Bobby!
I would have loved to stay home today. Too bad the weather still sucks...
Old Mar 15, 2010 | 06:02 AM
  #1333
I should have time this week, just have to get my car back together and make room in the garage. Worse case would be saturday.
Old Mar 15, 2010 | 06:24 AM
  #1334
chu's Avatar
chu
Pete, I bought a mint set of Evo 8 front and rear seats off a guy who rolled his car. Jim provided the hook-up.
Oh, for your Schroth harness, make sure you have something you could use to bend the tabs for the rear section of the harness. I used a large wrench and bent the tab about 45 degrees, and mounted it with the angle for the cutout on the bottom cushion. Fitted nicely. I had to call Marc to confirm the bending, and he did the same!
Old Mar 15, 2010 | 06:45 AM
  #1335
dek0026's Avatar
chu, your seat is awesome. like i said, i'd flip your car if you let me drive it with that seat.
i forgot to change the time on my alarm clock and my wife and i both woke up at like 6. that meant i drove in an hour later. my commute was brutal....it took over 2 hours to get in today. it seems the later it get in the morning the more aimless people on the roads are.
