Philadelphia's Classiest Drunkards
Old Nov 1, 2010 | 10:31 AM
  #13426
shuttlegoose's Avatar
if i can handle the injection mri so can you. usually they give you headphones too.
Old Nov 1, 2010 | 10:32 AM
  #13427
igo4bmx's Avatar
i've done an mri before
not worried about the injection, more about feeling like i'm stuck in a trashcan for ten mins lol
Old Nov 1, 2010 | 11:31 AM
  #13428
grillpt's Avatar
I've done the whole MRI w/injection thing... You get HOT, for like 2 seconds... its kinda weird.
Old Nov 1, 2010 | 12:00 PM
  #13429
igo4bmx's Avatar
so jealous
i'm battling injuries
while a kid i know gets to do this.
880 squat
625 or 645 (not sure) bench
705 DL
Old Nov 1, 2010 | 12:37 PM
  #13430
evremonde's Avatar
will removing the rear shocks require an alignment? I was thinking about how i would mark the bolts, but it does not seem necessary. Anyone know?
Old Nov 1, 2010 | 12:48 PM
  #13431
BBS's Avatar
BBS
Simply removing them putting them back? It won't change the alignment one bit. The bolt at the base isn't a camber bolt like the front
Old Nov 1, 2010 | 12:51 PM
  #13432
igo4bmx's Avatar
i would think it would be best to still get it aligned.
Old Nov 1, 2010 | 12:53 PM
  #13433
evremonde's Avatar
Correct. I need to swap out the bumpstops, but springs will remain the same.
I wont touch anything except for the two top bolts, and the one at the bottom (some tutorials recommend removing the lca).
Old Nov 1, 2010 | 01:00 PM
  #13434
AlwaysinBoost's Avatar
I agree with her.
Old Nov 1, 2010 | 01:11 PM
  #13435
chu's Avatar
chu
Kenny, why are you changing the bumpstops if you aren't lowering the car?
BTW, how did the Whiteline RCA kit go?
Old Nov 1, 2010 | 01:16 PM
  #13436
BBS's Avatar
BBS
Its MUCH easier to drop the lower control arm. Its just one extra bolt/nut and you'll save a lot of time. The camber is adjusted by the inner bolt so ure fine dropping the lca.
Old Nov 1, 2010 | 01:43 PM
  #13437
evremonde's Avatar
The new shocks did not have the little collar that holds the bumpstop in place, so currently they are "floating". The bump stops that came with the shocks have the collars in them, but I did not bring them with me (assumed i could use the bump stops from my existing shocks). Could not get the collar off of the kyb's.
I did not install the rck. The short story is that I chickened out.
If you turn the shock body a bit, it pops right over the lca
Old Nov 1, 2010 | 02:25 PM
  #13438
BBS's Avatar
BBS
Everyones told me the same thing but that's never worked for me ever! I don't mind since I've got air tool access (:
Old Nov 1, 2010 | 04:34 PM
  #13439
You guys are messing up bigtime. I'm having a blast at lvgp.
Old Nov 1, 2010 | 04:43 PM
  #13440
grillpt's Avatar
Kenny, your new shocks didn't come with new bumpstops, this is the rebuilt set? So confused...
Carson, you suck!
What would you guys pay for a loaded 07 CX-7, heated leather, navi, AWD, 83,700k?
