Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
My Boost Controler is killing me
Old May 12, 2005 | 07:57 PM
raiceboi697's Avatar
Wink My Boost Controler is killing me
i need some help i bought a greddy profec B spec 2 from a buddy and the install went well and for the first week i boosted 20 lbs with out trouble and today it started stopping at 10.5 to 11 lbs no matter what i set the settings to. could some body please help
Old May 12, 2005 | 07:58 PM
Help ME please
Old May 12, 2005 | 08:02 PM
PDXEvo's Avatar
I have heard of this happening a lot with the Greddy boost controllers. Wastegate alone will usually run around 12psi I believe. Is it possible your solenoid quit working? I would also check for a major boost leak and make sure all your hoses are where they are supposed to be. If you cant find anything then I would hook the stock solenoid and hosing back up to see if you can build boost.
Hope this gives you some direction!
Old May 12, 2005 | 11:56 PM
JeffR116's Avatar
Definitely sounds like a boost leak to me
Old May 13, 2005 | 12:00 AM
rvm's Avatar
rvm
boost leak for sure
Old May 13, 2005 | 08:03 AM
voidhawk's Avatar
Check the upper IC hose and BOV seal - most common places for a boost leak.
Old May 13, 2005 | 08:11 AM
jj_008's Avatar
Check to make sure all the vacuum/boost connections are secure. If they are, then the solenoid in your EBC has died.
Old May 17, 2005 | 09:35 PM
data_vr4's Avatar
it's not a boost leak
the wastegate actuator alone(no Boost control solenoid) will push 11-13psi....you most likely have a problem with your electronic boost controler
Old May 18, 2005 | 08:15 AM
MeKilla's Avatar
follow up? hows the car doin?
Old May 18, 2005 | 11:36 AM
doin better i can get to 18.7 max now so i think a lil ride and tune is in order. if anyone has this boost controller could u give me some tuneing tips please
Old May 21, 2005 | 08:24 PM
mikiblueeyes's Avatar
replace all hoses, to make sure its all good
2winscroll
Apr 19, 2016 07:04 PM
rexwagon1909
32
Jan 5, 2013 08:17 AM
travail
AEM EMS
Jul 31, 2009 08:31 AM
david350Z03
32
Jul 27, 2005 06:35 PM
2befast
Oct 6, 2004 11:10 PM
