Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
Conoco 92 vs Chevron 92?
Old Jan 22, 2007 | 10:15 AM
mrfred's Avatar
I've been running Chevron 92 in my cars for several years, but recently heard that Conoco 92 was pretty good quality too. Does anyone have any info on the quality of Conoco 92 gas compared to Chevron 92?
Old Jan 22, 2007 | 11:04 AM
GTisRule's Avatar
I used to commute 120 miles a day a few years ago, and I found that 76 gave me nearly 50 - 75! miles more out of a full tank in my REVO tuned GTi 1.8T. Seemed every other fuel type was the same though on the low end of milage
Old Jan 22, 2007 | 01:41 PM
EvolvinEvo's Avatar
imo 76 the best!
Old Jan 22, 2007 | 06:45 PM
andyktlee's Avatar
Pocket Mo
I use 76 because it's so close.
Old Jan 22, 2007 | 11:54 PM
Evo8you2007's Avatar
I'll vouch for 76 as well. They are the only ones selling anything higher than 92 on a pump in washington as well I believe.
Old Jan 23, 2007 | 12:01 AM
clarkkent06's Avatar
i usually use chevron (closer) but sometimes I'll use 76. too bad chevron doesn't have the "white pump" anymore, lol. stupid leaded gas
Old Jan 23, 2007 | 12:01 PM
value's Avatar
Yep, you can tell the diff if you use anything else but 76.
Old Jan 23, 2007 | 12:21 PM
which 76's have more than 92 on pump? there's one in auburn that sells race gas but they won't let you pump it in your car. There's a Cenex station in auburn which sells 94 pump i believe.
Old Jan 23, 2007 | 04:12 PM
voidhawk's Avatar
Some Shell stations carry 93.
Old Jan 23, 2007 | 06:54 PM
Iwantmore's Avatar
Once again, the Cenex on Pacific Ave in Parkland next to Jack in the Box sells 94 octane. I always see a muscle car or tuner there when I stop to fill up.
Old Jan 23, 2007 | 07:17 PM
signalauto27's Avatar
Can you name any off the top of your head? I wouldn't mind the extra 1 octane. : )
Old Jan 24, 2007 | 12:04 PM
GTisRule's Avatar
Some pumps that carry 93 is due to altitude. Most of the gas stations up in the cascades will have 93 where the stuff in town is 92 only due to the difference in oxygen levels up high vs. down low.
Old Jan 24, 2007 | 12:06 PM
lowbdgtmechanic's Avatar
mine never tasted chevron or anythin else except Shell and 76 but mostly 76!!!
Old Jan 24, 2007 | 12:12 PM
voidhawk's Avatar
I only know of the one close to me where I usually get my gas (Factoria).
Old Jan 24, 2007 | 12:22 PM
Nope, that is incorrect. At higher altitudes the air is under less pressure, therefore lowering the barometric pressure in the cylinders. Technically at higher elevations you need LESS octane. However with a turbocharger the octane would probably be about the same, so the 93 octane up in the hills is just coincidence.
with less o2, and the same amount of fuel, less combustion will take place which would make the engine run colder, hence the need for less octane, even at the same boost levels.
