Machine shop for engine build
Just looking for reputable machine shops in the area to go to when I need anything done. Preferably shops that have done work with 4g63's and imports often. Amount spent is not what I'm worried about, just good quality work. I know people must have good and/or bad experiences with machine shops and was just curious to hear what they were.
I worked with a local machine shop that built the race motors for Cascade Autosports open class EVO rally cars. Although they did good work I found them a little hard to work with. They wanted to upsell me and basically filled out a work order for everything from cleaning and full inspection to fitting and polishing every part. All I really wanted was a decking and boring along with some head work. I had to literally grab the work order and cross things off. All the while they told me I was foolish because I was spending money on nice parts and not letting them do all the work.
Anyway I stood my ground, but it was a battle, and made me pretty uneasy. I still ended up paying for a few things that looking back I shouldn't have but whatever. They did do a good job though. They have a torque plate for boring and honing the block which I doubt other places have for a 4G63, I think it's $250 for that. $100 to degrease and inspect, $100 to deck the block etc.
I spent $1500 for cleaning, boring, and decking the block, along with cleaning the head, doing a valve grind and cut for 1mm oversize valves, facing the head and putting it back together.
I know the Cascade guys pretty well as my friend Ross used to work there, and it's true that Pete the owner likes to do things his way. But he's uber **** and typically does top notch work. But you pay for the time that takes for sure.
If I did it again I would talk to the guys at English and maybe drive down to use the machine shop that works on their stuff. I was hoping to make it easier on me by using a place close by. But the negotiating, and explaining, required was pretty lame. A guy off the street bringing in an import engine for work is tough around here.
